Oh no... I've gone and done it - I was changing lenses, got bumped by a passerby and grabbed the body to move it out their way... and got a fingerprint on the mirror!
Whoops!
"Auch well..." I thought to myself - "it won't affect the image quality - only the viewfinder!"
Which is correct... well, mostly...It's right in the
middle of the viewfinder image and annoys me to no end! The smudge makes it hard for me to judge manual focus, and now that I think about it, it might be offsetting the metering too! Pfft! All in all, one of my more annoying "whoops!" scenarios that didn't actually involve breaking anything!
Well, what I wonder is what is the best/safest way to clean the mirror?
I've read on the photo.net forum the
following method may work:
The method described in the post is as follows:
Originally posted by 2009, PTurton, et.al.: 1. Use a blower to remove any dust from the mirror.
2. Soak a Kodak lens cleaning tissue in ethanol. (Be sure that the ethanol used does not contain any oils such as may be present in "Rubbing Alcohol".
3. Carefully drop a layer of this tissue onto the mirror covering the finger smear.
4. Slowly drag the tissue off the mirror. The only pressure on the mirror will be the weight of the wet tissue and the surface tension of the alcohol soaked tissue across the mirror surface.
5. Repeat as necessary using a fresh ethanol soaked tissue to completely remove the smear.
I found that my mirror was cleaned by 3 applications.
On the face of it, this strikes me as a reasonable way of going about it - but I just wanted to check before doing anything in case there was a better method! I know the usual advice for cleaning the mirror is "don't" but I really want to get rid of this smudge and I'm not sure I can afford sending it off for professional cleaning!
Any help would be appreciated!
