Originally posted by Sniggi Hello,
recently i bought a well worn sigmatel 135mm F1.8. The Lens has a lot of fungus in it and i was trying to Clean it but i couldnt find out how to open The Lens, to clean The glass elements. Is there a was to open it?
Hi Sniggi,
If you already have some experience and the right tools, this Sigmatel is relatively easy to open.
To get inside the front end, turn the focus ring to the minimum focus distance. Then you should see a small slot head screw above the focus ring. Loosen the screw just a couple turns - it doesn't need to be removed. (If the screw comes out, it'll be easy to lose and difficult to get back in place!)
With that screw loosened, the front part of the lens can now be unscrewed counterclockwise. Then you'll have access to the front elements.
With the top piece / retainer off, the front element should come out easily. Next, there's a spacer ring to lift out. And then a cemented triplet should also slide out easily.
There are also two elements behind the iris. When the iris is wide open, I believe the next element will also fall forward and out. And to get the rear element out, you'll need a spanner wrench or similar tool.
To remove the rear element, focus the lens to infinity and remove the mount adapter. Depending on which adapter you have on your lens, it might simply spin off, or it may require removing some screws first.
When the adapter is off, you'll have easier access to the retaining ring so it can be removed with a spanner.
Here's what my lens looked like when I had it apart for cleaning a few months ago:
In the picture, the second to last element is still inside the lens because I didn't need to clean it. But as I mentioned earlier, it should slide out toward the front of the lens.
And I took the aperture ring and mount off for my picture, but it's not necessary to remove them if you're just trying to get the rear element out.
Reason: clarification & added a photo
