Originally posted by A H Thompson Thanks. I have the KP and the SMC FA 1:1.4 50mm.I am hoping to get some images of children near outdoor lighted Christmas trees and other lighted ornaments. Should be no more 2-3 feet deep. I was attempting to set up around 12-15 feet away. My problem was that per internet advice- for greater depth of field, if the nearest object in the scene is 3 feet away then focus on something 6(double the distance of the near object) feet away manually or using autofocus and then switch to manual to prevent refocusing by the camera. I have not achieved a significantly deep dof using that approach. I was using f9 to allow lower iso and shutter speed of 1/100. Perhaps if I use f11 and increase the iso to 100-6400 and manually focus on one of the children then step back a few feet.
I think you are referring to the guideline that your total depth of field will be split roughly one-third in front of the focal point and two-thirds past the focal point. In your case, if you focus on a point 13 feet away from the camera, at f8, your depth of field will extend from
10.4 feet to 17.3 feet. In my experience you won't get better results with apertures narrower than f8 on an APS-C camera, so I don't suggest going to f11 to increase your depth of field. I have also found that if you focus on the subject (a child in this case) closest to you, our mental vision sees further away subjects as being in focus, even past the theoretical depth of field.
Lighted Christmas ornaments will skew the light meter in your camera, making the children too dark. If you haven't already used exposure compensation, I would set it to +2 stops, which will turn the lights into blown out highlights (so you won't capture details in the bulbs themselves, which isn't normally a big deal), but to make up those 2 stops of light you have to decrease the shutter speed by a factor of 4 (and I wouldn't go lower than 1/50 second), widen the aperture by 2 stops (from f9 to roughly f4.5) or increase the ISO setting by a factor of 4 (if it was 3200, increase it to 12,800) or better yet, a combination of those three settings.
Assuming that f9 and 1/100 was without exposure compensation, you could try f5.6 (for a total depth of field of 4.75 feet if focus point is 13 feet away), set the shutter for 1/60 second (and tell the kids to hold still), and let your camera select the right ISO. The built-in flash will also help to brighten up the children a bit, if you have a more powerful external flash, you will get even better results. Afterwards, you can brighten up the image with software, to make the children as bright as you want them to be. One last piece of advice, experiment with your settings to get lighter and darker pictures and choose the one that turned out the best, later.
