Originally posted by stevebrot Welcome to the Pentax Forums!
Do you see this with both optical and live view?
Hi Steve, yes it is with both optical and live view, but as I said, if in live view I can correct the tilt. As the composition adjustment moves the sensor, I conclude that the sensor must be misaligned.
I guess my ultimate question is, will it cost an arm and a leg to fix, or should I get another camera?
As I do a lot of landscapes and seascapes, this is a super PITA having to fix them all in Lightroom, and losing image every time.
Les
---------- Post added 12-13-18 at 09:44 PM ----------
Originally posted by BigMackCam Moderator's note:
A similar thread was started in our Visitors' Centre by the OP, before becoming a member. For the OP's benefit, I'm posting below all of the replies from that thread, and deleting it to avoid duplication:
Hi Steve:
Horizon correction seems to have no effect on or off.
In all my tests horizon was level.
composition adjustment only works with live view.
Thanks to all who have posted.
Les
