Hi there!
Forgive me if this thread should be put in the SLR lens forum instead. I'm sure some advent-friendly moderators can move it if that is the case
As the title explains, I have trouble stopping down to f/22 with my newly acquired, manual marvel. I can stop down to f/16 just fine, but the aperture blades will not move the slightest when turning the ring to f/22. Every sound and movement in the mechanism elsewhere seem all right. At first I thought that the difference from f/16 to f/22 might be so subtle that I wouldn't notice, but after looking closely, absolutely nothing happens. Every step up to f/16 work flawlessly.
The aperture blades don't seem oily, but they are not as snappy as my SMC Pentax-M 50 f/1.4. They are 'softer' and more quiet in their movement, and not as instantaneous as the 50 mm (which is
very quick) - but they are instant enough. I don't know if this is how it should be. It looks more like there is something mechanical somewhere that blocks the blades from moving, and not just grease.
I unscrewed the back K-mount plate (or what you would call it), just to see if there was something odd, but I couldn't find anything. I haven't taken a lens apart before, and I am therefore a bit reluctant to do so (even though I'm quite used to pick apart lots of other mechanical stuff).
Do you experts know what could be the issue, and how difficult it is to fix?
I plan on mostly using this lens with my old P30n for portraits, so I will probably never use f/22, but it's just good to know that my lens work as it should in every way.
Thanks!
