12-17-2018, 08:47 PM   #1
Manual to Automatic
New to the Forum. I just received the camera and only used my old K1000 lens on it. I changed the program for the manual lens. Now that I just receive a new 50 m lens, I cant remember what I did.
Do I have to reset everything back to initial setup , or does anyone know how to convert me back to using my auto lens so I can try it.
12-17-2018, 08:59 PM   #2
What camera? What lenses are you talking about?
12-17-2018, 09:16 PM   #3
noblepa's Avatar
What you probably did was set "Allow aperture setting other than A" on. This is set off by the factory (for no reason anyone has ever been able to find).
Without knowing what camera you have, its difficult to tell you exactly where in the menu this setting lives.
The good news is that you don't need to worry about it. The setting ALLOWS the use of manual aperture lenses. It doesn't REQUIRE it. Just mount you new 50mm automatic lens (which lens?) and fire away.
Most everyone here who ever uses manual lenses on their Pentax dslr enables that value and leaves it enabled.
Please come back and tell us what camera and what lenses you are using. It will make it a little easier to discuss.
12-18-2018, 06:19 AM   #4
UncleVanya's Avatar
Set the lens aperture ring to A if one exists. Set the camera mode dial to Av or P or Sv etc depending on what auto mode you want.
12-18-2018, 08:06 AM   #5
Seeker of Knowledge
aslyfox's Avatar
links for owner manuals for many Pentax cameras can be found by going to " Cameras " above
click
go to " Pentax camera review " and click
find your specific camera, click on it and check the " user reviews " of the " in depth review "
12-18-2018, 03:23 PM   #6
Just1MoreDave's Avatar
The OP's profile says K-5 II. I can't think of anything that would make an AF lens not work, except the switch on the front of the camera that says AF.S, C, MF. Put that on AF.S. If the lens is connected properly to the camera and the camera is awake, you should see an aperture on the top LCD, not F--. The same on the rear LCD and the status line in the viewfinder.
12-19-2018, 11:36 AM   #7
QuoteOriginally posted by leekil Quote
The Camera is an K5-II. The lens I was using is an old Pentax 200mm. I just received a new 50 mm
camera, lens, pentax help, photography, troubleshooting
Pentax K3 I am haviing problem, to change from Automatic to Manual Mode marconova Welcomes and Introductions 3 12-03-2017 01:05 PM
WhiteBalance mismatch when shifting from manual to Automatic (green) control VincentD Troubleshooting and Beginner Help 3 09-19-2016 11:49 AM
Your Thoughts On "Manual vs Automatic" Mode Photography OldPentaxFan Photographic Technique 42 02-07-2016 10:34 AM
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
Fujinon 55mm f1.8 - Surgery to change from AUTOMATIC to manual Pepe Guitarra Troubleshooting and Beginner Help 14 01-28-2012 07:33 PM
All times are GMT -7. The time now is 10:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
