12-28-2018, 05:23 PM   #1
ohfrankyboy's Avatar
Is the flash Metz Af-1 compatible with the K-70 ?
Hi guys,
Recently my old K20D is having the ''No card in the camera'' issue, blowing in it is not helping and nothing seems stuck in it, so I decided it might be time to change camera and I though of the k-70, but I can't find anywhere online if it's going to be compatible with my Metz 58 Af-1 ? Or do i need to get a new flash also ? Thanks for the help!
12-28-2018, 05:34 PM   #2
If it worked with the K20D, it will work with the K-70 AFAIK.
12-28-2018, 05:51 PM   #3
If a "Metz AF-1" exists, I have not seen one (I may be wrong).
To get a reliable answer from one of our members, you should specify about which Metz AF-1 you are speaking.
I own the Metz 24 AF-1 and the Metz 48 AF-1, and both are fully compatible with my *istDS, K200D, and K-5.
But in some cases there were years between the introduction of different Metz AF-1 models.
As Pentax seems to have modified the flash protocol several times (which obviously affects 3rd party flashes only), you cannot assume that, if one AF-1 model works, all the others will be ok, too.
12-28-2018, 06:07 PM   #4
QuoteOriginally posted by RKKS08 Quote
My apology, forgot to add it's the ''Metz 58 Af-1'' that I currently have.
12-29-2018, 05:11 AM   #5
WPRESTO's Avatar
The only problem that arises with Metz Pentax-dedicated compatibility is trying to use one designed for APS-C on a K1 when the latter is in full-frame mode.
12-29-2018, 11:53 AM   #6
So theres a big chance that the Metz 58 Af-1 will not be compatible with the K-70, cause I know they did an update for it to work with the K-1, which came out the same year as the k-70 ?
12-29-2018, 01:22 PM   #7
Bengan's Avatar
QuoteOriginally posted by WPRESTO Quote
Metz flashes work fine with the K-1 if the firmware (Metz firmware) has been updated.
12-29-2018, 05:51 PM   #8
Des
Des's Avatar
I have the 58 AF-1. It works fine with my K-3 and K-S2, so it should certainly work with the K-70. Just make sure you install the latest firmware.
As for the new camera, I'd suggest you also look at the KP, if the price is similar to the K-70. (There's only $A100 between them here at present.) The KP is a more advanced camera.
12-30-2018, 02:33 PM - 1 Like   #9
The KP is much closer to a K20D than would a K-70, in terms of build quality and controls, being that the K20D was a flagship model. I still have my K20D, now seldom used, as well as my often-used KP. While the KP is not quite a flagship model in every respect of features and controls, it is in line quality-wise. The K20D is a very meaty camera in size and feel. The KP is of even higher quality as to its VF, magnesium alloy construction, and advanced features, but in a very svelte slimmer design, which is expandable via various grips, including the optional battery grip.
01-05-2019, 12:33 PM - 1 Like   #10
Wasp's Avatar
There might be an easy fix for the K20D. I once had a memory card problem in my K10D. The camera just wouldn't read any card. It turned out to be that a tiny piece of plastic was lodged in the slot, preventing the card from going all the way in. I managed to shake the piece of plastic out and the camera was back in business. By the looks of it, it was a piece of a write protect switch. What a stupid that was!
af-1, camera, flash, flash metz af-1, k-70, metz, pentax help, photography, troubleshooting
For Sale - Sold: Metz 58 AF-1 flash & Metz P76 battery pack + extras. gsrokmix Sold Items 4 03-11-2018 06:21 PM
Cactus V6 II with Pentax K3, Pentax K1 + Metz 58 AF-2, Metz 52 AF-1 eriksvec Flashes, Lighting, and Studio 3 02-17-2017 02:38 AM
K-3 II + Metz 48 AF-1 not compatible? Rayn Pentax K-3 & K-3 II 4 11-12-2015 01:38 PM
CTR-301P compatible with Metz 48 AF-1? L(2) Flashes, Lighting, and Studio 2 11-16-2009 11:07 PM
Is the Metz 58 AF-1 Flash Compatible with K2000/KM? lawsonstone Pentax DSLR Discussion 3 06-07-2009 02:05 AM
All times are GMT -7. The time now is 06:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
