12-30-2018, 07:06 PM   #1
Focus select in live view
New to ks2. Trying to get the focus select working in live view. According to the manual I should long press the center button and then use the left-right and up-down keys to move focus point. My long press just zooms into the scene. What am I doing wrong - any
help will be much appreciated.
12-30-2018, 08:58 PM   #2
Hello and welcome to the forum!
I use a K-S2 as well
I believe that by default the contrast autofocus is set to auto. To change it and do as you wish (select your focus point in live view) you should look into the third page of the picture menu, there is the live view option, press it and change "Contrast AF" to select (the small rectangle with four arrows around it). Now you should be able to long press the OK button to select your autofocus point, take note that a single press will just zoom the live view.
It's a bit cumbersome to change, but if you use this option frequently you can save it to one of the User slots on the mode dial.
12-30-2018, 10:00 PM   #3
Indeed, look for the 1st icon from the left in the third row of the control panel, or in the main menu as state above. Once you've enabled select mode, you'll be able to change the focus area as expected.
Note that select CDAF is typically slower than multi-point mode, but it does allow you to pinpoint the focus point accurately.
12-31-2018, 09:05 AM   #4
Wow thanks guys for the quick reply.
I should have added more details in my post. I already did change the focus mode to select. It doesn’t work, I am starting to think that something is wrong with my camera. Do I need to return it or is it a software glitch which can be fixed through an update.
camera, focus, pentax help, photography, press, troubleshooting, view
Looking for info. How do I select a focus point in live view? normhead Pentax DSLR Discussion 2 08-22-2017 03:45 PM
live view noise and smc dfa 100mm f2.8 macro lens not focusing in live view tommygunn84 Troubleshooting and Beginner Help 7 11-24-2016 08:59 PM
Typical live view humming, when not in live view. lightsource Pentax K-1 8 05-05-2016 02:20 AM
Select focus in Live view Shellz19 Pentax K-3 5 04-12-2014 07:24 AM
K-5 Select Af point in live view telfish Pentax K-5 5 10-21-2010 11:38 AM
All times are GMT -7. The time now is 03:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
