Originally posted by billdotjr Bright made the dark part darker, but for example the tree was just black then
The "Bright" setting has contrast up by default to +1, as well as sharpening up by the same figure. It also has a richer color palette. You can go into the menu of the "Bright" category and reduce contrast back to mid-point if desired. Or you could use another category as you did. I don't know the K-m controls, so I cannot be sure enough to help you open the Custom Image category menu to implement adjustments. Maybe via the info button? when you bring up the links to various adjustments, the 4 buttons surrounding the ok button will serve for navigation in making and selecting adjustments.
This contrast change would only be for high-contrast scenes, of course. For most scenes, return to the standard setting. It is also here where you can increase sharpening level, adding another notch to +2, and also adding "Fine sharpening" by using your thumb dial, also putting an "F" by the "S". In fact, you might just leave the sharpening level as is, just adding the "Fine sharpening" I remember now, with the K200D's design the camera needed no further sharpening than default- just the "Fine Sharpening" aspect did the trick. Test reviews revealed any higher level would overdo a good thing with the K200D.
This will improve the camera's JPEG output yet more.
