01-18-2019, 07:02 AM   #1
SunnyG.'s Avatar
Lens stuck on K200D
I mounted my k-50 kit lens, 18-55 on my k200D And now it won't come off! What should I do???
01-18-2019, 09:30 AM - 1 Like   #2
it could be that the af isn't disengaging. Put the af-mf selector on to mf and see if that helps.
01-18-2019, 11:06 AM   #3
Not a Number's Avatar
The AF drive shaft should be withdrawn with the lens release button. Try marcusBMG as switching to MF will withdraw the shaft as well.
Is this a lens with a "Ricoh pin"?
01-18-2019, 11:09 AM   #4
SunnyG.'s Avatar
QuoteOriginally posted by marcusBMG Quote
I tried the mf. But still the lens isn't coming out!
---------- Post added 01-18-19 at 11:15 AM ----------
No no! It's the kit lens of my k50! 18-55! Red color kit lens of my red color K-50
01-18-2019, 11:24 AM   #5
UncleVanya's Avatar
QuoteOriginally posted by SunnyG. Quote
Try switching MF/AF a few times while gentle twisting the mounted lens back and forth a bit to see if that releases anything. If that doesnn't work try a powerful flashlight and look where the AF shaft is supposed to engage and see if it appears stuck in the up (engaged) position. You may need to use the techniques used for lenses with the Ricoh pin to try to push it back down.
So sorry about this happening to you.
01-18-2019, 12:57 PM - 1 Like   #6
Are you sure the lens release button is working as it should?
If your lens is not WR, you may be able to see whether the bolt is retracting far enough to set the lens free to rotate the bayonet.
01-18-2019, 07:37 PM   #7
All I can suggest is to fiddle, wiggle and jiggle without too much force and hope something decides to move the way it should
af, camera, color, k200d, kit, lens, mf, pentax help, photography, shaft, troubleshooting
KX stuck in autofocus, but switch is stuck in MF icywarm Troubleshooting and Beginner Help 4 08-07-2012 07:21 AM
K200D Dead / Stuck Pixel ? vk4akp Troubleshooting and Beginner Help 6 05-16-2011 02:45 PM
PK-M 50/1.4 ring stuck, back-plate screws stuck fungiman_md Troubleshooting and Beginner Help 4 05-10-2011 12:54 AM
k200D got stuck doing 8fps TOUGEFC Pentax DSLR Discussion 5 10-11-2010 10:36 PM
K200D shutter stuck when shooting? D4rknezz Pentax Camera and Field Accessories 2 06-16-2010 06:22 AM
All times are GMT -7. The time now is 10:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
