Originally posted by Ash Ooh, will give that also a go should the problem resurface. Seems to be a few diagnostic possibilities here...
Well, there is a problem of battery management with the K1 (haven't had a chance to verify on the K1 II, but I believe it's the same): I already had the camera switch off when transitioning between the in-camera battery and grip. There is a choice in the menu: Auto, grip-first, camera-first. I initially used the K1 with the default "Auto" grip setting, and I had the K1 switch off in the middle of a burst when it attempted to switch batteries automatically. On the K1, the camera isn't able to switch automatically fast enough from in camera battery to grip battery, so during the switching time the camera will sometimes switch off instead of successfully switch to the alternate battery. By default, the switch is set to Auto. After I had set the power source to "Grip first" instead of "Auto", the problem occurred less but never fully gone. That said, your problem is not necessarily related to the grip.
