Originally posted by biz-engineer I checked mine, I don't see how this could be happening. You need a fully charged battery, clean contacts in case there would be a voltage drop at the startup that would screw-up the start-up. Your best thing to do is to reset everything to factory defaults. Switch off the camera. Remove the lens. Remove battery. Set the dials to default. Put the battery back in. Switch on again.
That might just be it. The contacts I mean. There was a small degree of grease lining some of them on the camera body that I wiped off and will test its effect with time. But I agree, it shouldn’t be happening. I always check to see that the battery is reasonably charged, although if it didn’t have enough charge it wouldn’t start up fine after depressing the shutter, would it?
