01-28-2019, 04:08 PM   #1
Loose lens barrel
Hi,
I recently tried a polarized filter on my Pentax 21 mm/F 3,2 HD DA AL LIMITED, which got stuck at some point. I used a lens wrench to remove it but had to struggle more than expected. After I few days, I noticed that the inner barrel was rotating a bit (1-2 mm) and that this rotation would make the aperture blades opening/closing.
I've seen a couple of other threads mentioning loose barrels, but none mentioned that is was causing apertures blades to move inside the lens, so i'm a bit worried here. How bad is it ?
Thanks a lot for your help for your help
barrel, bit, blades, camera, lens, pentax help, photography, troubleshooting
Tamron 28-75 F2.8 Loose barrel W.j.christy Pentax SLR Lens Discussion 4 03-15-2017 12:15 PM
Pentax A* 600 F5.6 Loose Barrel Odinz Pentax SLR Lens Discussion 5 09-10-2016 09:29 AM
Re: Help requested regarding new DA *200: possible loose focus barrel candgpics Pentax SLR Lens Discussion 2 03-15-2016 05:21 AM
Pentax-F 35-70mm lens front barrel is loose violini Pentax SLR Lens Discussion 2 08-08-2011 10:42 PM
Pentax FA 80-320mm - loose front barrel jeallen01 Pentax SLR Lens Discussion 4 01-26-2009 01:23 PM
All times are GMT -7. The time now is 02:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
