02-05-2019, 03:55 AM   #1
K3ll EV Use
Hi,
I usually shoot in TAV mode with my K3ll to give me a decent amount of control. In the camera manual it shows that in this mode (TAV) you can also adjust the EV function. However when taking a shot in TAV mode it makes no difference what EV figure I set, it has no impact.
Am I miss-reading the manual or is there a further setting I should be adjusting?
Andrew
02-05-2019, 04:22 AM   #2
Check your ISO setting when you use exposure compensation. I thought TAV locked in Shutter Speed and Aperture and varied ISO to obtain the correct exposure.
Regards
Chris
02-05-2019, 04:34 AM   #3
Hi Chris.
This is what I thought but the manual indicates different (Or do I miss-read it). See page 40.
Andrew
02-05-2019, 05:17 AM   #4
Seeker of Knowledge
aslyfox's Avatar
you might want to consider getting the Ebook for the K 3 and K 3 II
check with vendor for current pricing:
Pentax eBooks all 40% off until the end of 2018! - PentaxForums.com
02-05-2019, 06:36 AM   #5
pschlute's Avatar
QuoteOriginally posted by VolvoKid Quote
Hi Chris.
Andrew
Think you are mis-reading it.
EC in TAv mode will compensate by increasing/decreasing the ISO by the amount of EC you have dialed in.
There are two situations where the EC compensation will fail:
1. if you dial + compensation which would take the ISO above the limit you have set for Auto ISO. Solution is to remove or raise the limit on Auto ISO.
2. when you dial in - compensation and this would take the ISO below the minimum (100).
---------- Post added 02-05-19 at 01:44 PM ----------
You have written EV. Are you actually meanung EC (exposure compensation) ? Or something else ?
02-05-2019, 09:24 AM   #6
Just1MoreDave's Avatar
The camera should tell you in either case by the ISO setting flashing on all of the displays. Any blinking/flashing display means some conflict between settings and limits.
auto, camera, compensation, ec, ev, iso, k3ll ev, limit, mode, pentax help, photography, tav, troubleshooting
manual mode: EV +/- , multi-exposure composite Emirena Pentax K-70 19 07-21-2018 09:32 PM
K3ll on camera noise reduction settings for birding pasorro Pentax DSLR Discussion 5 11-16-2017 04:34 PM
Can I remove EV correction, EV bracketing information from screen? rapucha Pentax K-01 1 01-25-2017 03:54 PM
When/what k3ll replacement ? BarryE Pentax K-3 38 09-21-2016 03:26 PM
B/H Pentax K3ll $729.00 New Or Used??? Tony3d Pentax DSLR Discussion 3 01-10-2016 10:26 AM
All times are GMT -7. The time now is 12:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
