03-04-2019, 01:57 PM   #1
16-50mm vignetting
Delivered today from a reputable source is a slightly used in mint condition 16- 50 mm PENTAX 1:2.8 ED AL [IF] SDM lens...Upon testing, it has serious vignetting at all focal lengths...Any Ideas...is it me or is the lens bad?
FinePix S4530  Photo
03-04-2019, 01:59 PM   #2
boriscleto's Avatar
On a K-1? Perfectly normal. It's a DA* lens...Try it in crop mode...
03-04-2019, 03:28 PM - 1 Like   #3
rogerstg's Avatar
It would help your cause to post examples of the problem instead of a pic of the lens. FWIW, assuming a crop camera, that filter might cause an issue at 16-18mm.
03-04-2019, 04:05 PM   #4
amateur dirt farmer
pepperberry farm's Avatar
QuoteOriginally posted by boriscleto Quote
^^ this ^^
it's not a FF lens (I don't think it's on the FF-compatible list, is it?), so some vignetting should be expected....
03-05-2019, 10:25 AM - 1 Like   #5
traderdrew's Avatar
QuoteOriginally posted by pepperberry farm Quote
^^ this ^^
It's not a FF lens. I have a copy. It's a great lens. I don't care what anyone says about it. The 15-30mm F/2.8 shouldn't have any noticeable vignetting. If I had a K-1 I would buy that lens.
03-05-2019, 11:31 PM   #6
clackers's Avatar
Yeah, you've said elsewhere you own a K-1, Masterfire. In Nikon terms, you've bought a DX lens but have an FX body.
03-06-2019, 01:19 AM   #7
pschlute's Avatar
QuoteOriginally posted by traderdrew Quote
The Pentax 15-30 is a D-FA lens, designed for FF and works wonderfully with the K-1
03-06-2019, 08:09 AM - 1 Like   #8
QuoteOriginally posted by MASTERFIRE Quote
Thank you. lens returned.
---------- Post added 03-06-19 at 08:12 AM ----------
Thanks! I certainly wanted the 50 mm fl available, but will look into your recommendation
---------- Post added 03-06-19 at 08:15 AM ----------
Thanks...a mistake on my part...I've returned the 16-50.
---------- Post added 03-06-19 at 08:17 AM ----------
^^ this ^^
Thanks...I didn't do my homework. I have returned the 16-50 mm lens.
---------- Post added 03-06-19 at 08:19 AM ----------
Thank you, I hope to find one I can afford.
---------- Post added 03-06-19 at 08:23 AM ----------
QuoteOriginally posted by rogerstg Quote
My first K 1...you need not be critical of my post...I wanted to make sure the forum knew exactly the lens I had purchased. It is now returned, and I've learned a lot. Best regards.
---------- Post added 03-06-19 at 08:25 AM ----------
Thank you. Your input is most appreciated. Best regards!
---------- Post added 03-06-19 at 08:32 AM ----------
Thank you, I hoped to have 50 mm available without changing lenses...should have asked here before my purchase, which is returned. My Sigma 17-35 is a fine lens. I only have so much room in my camera case, so a 16-50 mm fl appealed. My ignorance caused my mistake, but lens is returned. Best regards!
---------- Post added 03-06-19 at 08:36 AM ----------
Thanks! I'll start shopping, but sure wanted the 50 mm fl. I've returned the 16-50. Your are kind to respond!
---------- Post added 03-06-19 at 08:37 AM ----------
Thanks! I've returned the 16-50 DA.
---------- Post added 03-06-19 at 08:39 AM ----------
Thanks, my mistake...lens returned. All the best to you.
---------- Post added 03-06-19 at 08:42 AM ----------
Thanks, lens returned.
03-06-2019, 09:18 AM   #9
pschlute's Avatar
Yeah the D-FA 15-30 is not cheap. if you want a very good 50mm lens and don't want to spend a fortune I recommend the FA 50mm 1.4 or 1.7. They can be had for a reasonable price new, and terrific value second hand. Autofocus and auto-exposure all work with the FA series which were originally designed for 35 film cameras.
I got mine (1.4) second hand, like new for about 140
https://www.pentaxforums.com/lensreviews/SMC-Pentax-FA-50mm-F1.7-Lens.html
03-06-2019, 10:50 AM   #10
rogerstg's Avatar
In the future, I'll remember not to offer you advice
03-06-2019, 01:25 PM   #11
pschlute's Avatar
Here is one in the classifieds Pentax SMCP-FA 50mm f/1.4 Lens - PentaxForums.com
camera, care, cause, crop, d-fa, f/2.8, ff, fl, k-1, lens, mint condition, mm, pentax, pentax 16-50 vignetting, pentax help, photography, post, troubleshooting
Nature A very pretty yellow flower with some nice vignetting. Tonytee Post Your Photos! 4 10-02-2019 12:14 AM
Seeking advice: DFA Zooms vignetting on film SLRs yucafrita Pentax Film SLR Discussion 14 11-23-2017 12:24 AM
Vignetting at 40mm for my HD20-40mm lens normal? jochenmaas Pentax SLR Lens Discussion 3 06-25-2017 01:31 PM
Vignetting in K20D viewfinder Bikerjeff Troubleshooting and Beginner Help 6 03-26-2017 03:30 AM
vignetting of 50mm F1.4 lenses on film bodies Lowell Goudge Pentax Film SLR Discussion 23 01-04-2011 08:01 AM
All times are GMT -7. The time now is 01:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
