Show Printable Version 9 Likes Search this Thread
03-05-2019, 12:19 AM   #1
mroeder75's Avatar
Purpose of multiple focus points?
What is the purpose of multiple focus points? With my old ME Super, I just lined up the focus with the line in the middle.
Do these focus points just give an average focus over the breadth of all focus points? They can't possibly focus on everything in the field of focus points if depth is different on each point.
Wouldn't I do better to have one focus point to keep my focus on what I was to focus upon?
03-05-2019, 12:25 AM - 1 Like   #2
Sandy Hancock's Avatar
Tracking of moving objects.
Focussing deliberately on objects not in the centre of the frame.
I'm sure there are others.
03-05-2019, 01:01 AM   #3
As Sandy says, for tracking moving objects, but ... perhaps panning can give better, more controlled shots. It would be interesting to see how many users have their usual settings on anything other than spot/centre for stills. It is one of the first things I do when I set up user settings on any camera I've owned. Using a point focus either through Live View or just locking focus and re-composing is an ingrained technique. Why leave the camera to guess what I want in focus?
03-05-2019, 01:25 AM - 2 Likes   #4
Paul the Sunman's Avatar
I use centre spot focus most of the time, but area focus for birds in flight for example, and sometimes for street photography where things are changing too rapidly for me to spot focus. And of course, I often move single spot focus off centre.
03-05-2019, 01:40 AM - 3 Likes   #5
Digitiser of Film
BigMackCam's Avatar
Like Paul, I use centre spot most of the time, but if I'm shooting a moving object I'll switch to area.
I also find myself using a single selectable AF point more often these days when focusing on an off-centre target, especially when I'm shooting at faster apertures and, hence, shallower depth of field. Focus and recompose isn't the most accurate approach in these situations, particularly with lenses that have pronounced field curvature...
03-05-2019, 04:56 AM   #6
Medex's Avatar
How do you find focus accuracy using off-center focus points with let's say f1,4 lenses. Those focus points have f5,6 sensitivity, so IMHO the accurate focus with fast lenses are quite challengable for the camera.
03-05-2019, 05:13 AM - 1 Like   #7
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by Medex Quote
Honestly, I very rarely shoot at f/1.4 in those situations. I'm more likely to shoot at f/2.8 - f/4 (sometimes smaller still) depending on the focal length and how much subject isolation I want. Going back briefly through my catalogue, most of the wide open stuff I've shot has been central to the frame, and many are just test shots, playing around with a lens to see what it can do At my usual apertures, there's enough depth of field to allow for very slight focus inaccuracy. I haven't noticed any significant problems with my approach, but my tolerance for focus accuracy might be slightly different to yours...
03-05-2019, 07:22 AM - 2 Likes   #8
photoptimist's Avatar
Off-center compositions (typically rule-of-thirds) is my primary use of off-center focus points
For portraits of a musician at a concert, I'll set the focus point one-third over in the frame, angle the camera so the musician's face is under the focus point, and shoot away.
For these kinds of events, there's no time for focus-and-recompose because the facial expressions are constantly changing.
03-05-2019, 07:51 AM   #9
mroeder75's Avatar
You all have given me advice I need that I can generally use single point focusing. I do not know how to change to single point focus but can figure it out. How do you change he focus point within the frame?
I achieve some of the same off-center focus as you describe by switching from AF to MF and panning. Now if I could just compose my photo better.
PENTAX K-5  Photo
03-05-2019, 09:44 AM   #10
What mode are you using there? What I would do is center point focus, focus on the fawn, then reframe. If you want to move the focus point that is active, it depends on the model. The K1 there is a button above the four button pad that toggles point selection. The K3 was different. Look at your manual.
03-05-2019, 09:55 AM   #11
Just1MoreDave's Avatar
QuoteOriginally posted by mroeder75 Quote
There's a switch on the back of the camera, between the green button and LV button. That goes between single point, SEL (to select your own point), and AUTO. If you switch to SEL you can move the point around with the arrow keys. You should experiment with moving the point, maybe using the back button for focusing too. The idea is to find something that works best for you among many options.
03-05-2019, 10:18 AM   #12
There have been a lot of good posts on how they can be used. I am also going to throw out the cynical response that it's becoming a marketing item. I can't tell you how many you really need, but my guess is some of these specs are hitting the silly level.
03-05-2019, 11:41 AM   #13
Larrymc's Avatar
You might want to not be zoomed in so tightly and you would have a wider FOV that would allow cropping to change your composition just a bit and also allow the use of an alternate focus point once you get familiar with that feature.
03-05-2019, 12:16 PM   #14
mroeder75's Avatar
QuoteOriginally posted by Larrymc Quote
You are right; I don't do enough cropping. I would guess this doe will return to the cemetery with new fawns this year, if she survives winter.She used the cemetery for her daycare starting around May or June and continuing much of last summer. She would return to pick up her fawns daily between about 4:30 - 6:30 p.m. I may have the opportunity to take better deer photos this coming summer.
03-06-2019, 10:17 PM   #15
mroeder75's Avatar
QuoteOriginally posted by Just1MoreDave Quote
I hope you can help me out. I have a K5. I am trying to experiment, as you suggest. This 3-way switch has a box with a single point in the center - what is that for?
SEL: What is that for?
And a green box that says auto. What is it for?
Somehow in Live view I have so many things unrelated to focus points showing when I am merely trying to work on focus points I am not sure if I pressed a wrong button, that wants me to work on white balance, or what is gong on here. I have thought of upgrading cameras, but this one is so advanced, and I can't figure it out even with reading the manual. I am open to assistance.
camera, focus, pentax help, photography, purpose, troubleshooting
Does the number of focus points improve focus speeds? steve_k Pentax DSLR Discussion 27 03-11-2019 07:53 PM
SAFOX 12 autofocus can indicate multiple points in focus! bwDraco Pentax K-1 & K-1 II 16 04-29-2016 01:24 AM
AF point behavior with larger subjects covering multiple points bwDraco Pentax K-3 & K-3 II 13 10-17-2013 07:52 AM
multiple multiple exposure Donald Post Your Photos! 6 05-17-2007 07:43 PM
All times are GMT -7. The time now is 11:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
