Originally posted by SGOMMO7
I've tried both "1" and "2" in the C menu and there is nothing that I can find in the manuals. Everything works as I think it should with the 28-45 and nothing I try works with the 90mm.
The 90mm should make a quick buzz/chirp/tick at power on of the camera. It can be very subtle. You can also look through the optical viewfinder when you power on the camera - and you will see the scene move a tiny bit when the SR motor kicks in. If the scene doesnt move, and there is no sound, then the lens is not working.
I found that the "Shaky Hand Icon" in the display can be confusing. It does NOT mean that you have an SR lens with SR switch turned ON. It means the SR motors are running or not.
What it actually means is:
Shaky Hand ON = SR is actively optically stabilizing the lens - the mechanism is energized, and you can see through the viewfinder that the target is not bouncing around much.
Shaky Hand OFF = SR is not doing anything, even if it is turned on/enabled.
OFF can mean that it is disabled OR it is not actually running the lens SR mechanism right now.
ON only means that the SR motors are actually moving the lens around right this moment.
The camera has to reach focus (or start trying to focus) before it will start actually powering on the SR mechanism.
SR stays running for about 10 seconds after you let go of the shutter halfway. Then it goes OFF again, and icon changes.
Here's how to check it out easily:
Set Menu C4 28 = 2 so that SR comes on when you depress the shutter button halfway.
Put LV on by hitting the Red Dot button next to the trashcan.
You'll see a live image, but the Shaky Hand Icon will be OFF.
Aim the camera at something a bit distant (a fence post or something 20 feet or so away).
Depress the shutter button halfway.
After the camera finishes autofocusing, you should see the fence post stabilizes and the Shaky Hand Icon come ON.
I don't like the way this works, but it seems to be correct.
This makes me think it is a bad lens, but I have had it verified by two parties that it is apparently working when they test it on other cameras.
Was this a new lens and/or under warranty, and did it go to a Ricoh authorized service center?
Did you contact them right away after receiving the supposedly repaired lens?
When mine camer back from service, the tech comment on the worksheet said: "Replaced SR mechanism + lens barrel. Checked cleaned + adjusted". You might asked them what they did to fix it, if that wasnt on the work order/repair invoice.
Some other things to try if it doesn't go:
You might also check if you have the latest firmware in your camera v1.30
Power off the camera, unmount the lens. Power on the camera with no lens. Power off. Remount your lens. Power on, try again.
Write down your custom settings, and reset the camera.
