Originally posted by ramseybuckeye Good answers so far, look at your file sizes in Explorer and you'll see lots of different sized files (unless you shot the same image over and over). The battery has nothing to do with the file sizes.
You are correct sir. I did shoot the same image all the way through. I am aware that the battery has no relevance to the file sizes, I merely wished to be informative and also to be certain to have enough juice to finish the experiment. On that note, this past Wednesday I went out and shot (with a fully charged OEM battery) 110 images and the battery went down to 75% capacity. A different topic I know and I will post the bizarre happenings on Wednesday, when I can get my thoughts organized. An awful day to be sure.
Thanks very much for the info.
Tony
---------- Post added 03-13-19 at 10:27 PM ----------
Originally posted by BigMackCam The amount of available shots remaining is calculated based on an average sized image file. If your images take up less space - perhaps because they're all taken at base ISO (with very little noise) or there isn't much fine detail in them, or there's a limited colour palette - you'll get more shots than the estimate
I feel as though I am in tune with what you are saying. There is one area I am having difficulty in comprehending and that is: Reality. I mean for every shutter activation, the total count was reduced by a factor of one, and that happened all the way to the end. I know this because I was counting along with the display counter. So if I agree with the total of zero, how can the camera come up with 260 actuations more than the actual? I understand what you stated, however I do not understand how a file can replicate itself based on ISO settings or any preset settings. You see, I am using Photo Editor 10 to upload images into my computer. This app., came with Windows 10 and for the first three years it functioned flawlessly. Within the last 8 months it has been a real nightmare to work with and I have seen many formal complaints forwarded to the manufacturer. The only recourse I have is to conduct the experiment again, upload the photos and take an actual count to confirm that the number is accurate in Photo Editor 10.
Here is the main reason I am suspect of both Photo Editor 10 and the K-50. This past Wednesday I went out and shot (with a fully charged OEM battery) 110 shots and the power level indicator went down to approximately 75%. When I conducted this experiment yesterday after 1,109 shots, the power level indicator remained at full power level.
How can this be? Perhaps the simplest thing to do is to have the K-50 checked out and see what the results are.
Thanks again, Tony
PS I will post what happened to me on Wednesday at first chance. In a nutshell, it was a cross between: The Twilight Zone and The Outer Limits.
