04-08-2019, 06:59 AM   #1
K-1 II high ISO failure
I got some weird results when trying ISO 12,800 for the first time on my K-1 II (converted K-1). ISO 6400 worked fine (second image below) so I thought I would push it one more stop just to see how it looked. Any ideas on why this happened?
PENTAX K-1 Mark II  Photo
04-08-2019, 07:47 AM   #2
CarlJF's Avatar
Is the RAW looking like that ? It looks like a negative filter effect was applied to the first picture...
04-08-2019, 07:50 AM   #3
normhead's Avatar
What does the histogram look like?
04-08-2019, 08:02 AM   #4
bkpix's Avatar
The exposures in the EXIF are wildly different from each other.
04-08-2019, 08:28 AM   #5
Here's a couple of ISO 6400 shots from just before and after with similar exposures. All the ISO 12800 shots look the same as the original sample. Changing ISO was the only change I made between shots. I am using LR6 for PP but Faststone Image Viewer shows the same thing.
04-08-2019, 08:31 AM   #6
normhead's Avatar
I've had the exposure on a shot in a burst go wonky before. How many shots had this result?
From my K-1, 6400 isn't even all that high for these cameras.
Even 25600 is doable....
I guess it could be a circuit board issue.
04-08-2019, 08:41 AM   #7
I was in single shot mode, never use burst mode. All the ISO 12800 shots had the same extreme posterisation look. Here's another taken seconds later.
---------- Post added 8th Apr 2019 at 10:02 ----------
Just tried daylight shots, fails at ISO12800 and above. Looks like my camera is going back for repair.
04-08-2019, 09:57 AM   #8
roberrl's Avatar
Goodwood Members Meeting?
04-08-2019, 10:06 AM   #9
QuoteOriginally posted by roberrl Quote
Yes, Goodwood 77MM. Lovely hearing and seeing the Le Mans cars doing their stuff again. They got a bit of a shift on in daylight on Sunday.
04-17-2019, 02:50 PM - 3 Likes   #10
Update: Camera repaired and back in use functioning normally at all ISO settings. Work carried out under warranty included repair and recalibration of main circuit board and sensor. Neither the technician nor Ricoh UK had seen this fault before and had to consult Japan so it clearly isn't a common type of failure.
04-18-2019, 09:24 AM   #11
TerryL's Avatar
I really like the first one, Norm.
Terry
04-18-2019, 09:43 AM   #12
normhead's Avatar
QuoteOriginally posted by TerryL Quote
Terry
Logging Day at Algonquin Park... my best shot of the day I can't even post, it was an underage participant and I couldn't get parental permission.
Loggers day - Algonquin Park - PentaxForums.com
That one was taken in the blacksmith's shop.
The old blacksmith is a personal friend.
camera, ii, ii high iso, iso, k-1, k-1 ii, mode, pentax help, photography, shots, troubleshooting
The dreaded SDM failure topic - Nikon AF motor failure perspective beholder3 Pentax SLR Lens Discussion 21 07-19-2018 10:02 PM
Nature High ISO and high shutter speeds charliezap Post Your Photos! 3 09-15-2015 02:10 PM
People K-5 high ISO... how high can we really go... igor Post Your Photos! 2 03-24-2012 01:10 AM
Example of AF, DR, high ISO and high shutter speed on K-5 benisona Pentax DSLR Discussion 17 11-30-2010 02:25 PM
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 72 05-10-2010 04:24 PM
All times are GMT -7. The time now is 01:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
