04-09-2019, 01:12 PM   #1
Pentax-FA* 24mm f2 problems
I just received this lens: SMC Pentax-FA* 24mm F2 AL [IF] Reviews - FA Prime Lenses - Pentax Lens Reviews & Lens Database
after ordering from keh, and the autofocus doesn't seem to be doing anything at all. No noise, no focus. MF seems to work ok.
I am using a K-01, with the switch on AF. My other lenses with autofocus are the 40mm XS, and two Pentax-F zoom lenses. AF works fine on all when I push the shutter release halfway.
I'm pretty new to autofocus lenses, so before I send it back for a refund or exchange, is there something obvious that I'm missing? An easy fix or a setting I'm unaware of?
04-09-2019, 01:19 PM - 1 Like   #2
The focus ring itself pushes forward and back, and acts as a switch. (You'll see this referred to as a "clutch" in reviews -- several FA lenses and some Sigmas have this type of AF/MF switch on the lens.) You should see the word "autofocus" below the ring when AF is engaged -- if it isn't push the ring towards the front of the lens. (See pictures in the review you linked to -- look at supersize)
04-09-2019, 01:31 PM   #3
Thanks! I'm glad it was something simple
04-09-2019, 01:39 PM - 1 Like   #4
Mikesul's Avatar
Don't feel bad. Most of us who have owned this lens or the FA* 85 1.4 have panicked about the same thing. Easy fix and a nice feature.
04-09-2019, 02:04 PM - 1 Like   #5
amateur dirt farmer / mod
pepperberry farm's Avatar
same thing happened to me when I received my FA*300/4.5...
04-09-2019, 02:04 PM   #6
Well, now I have a new problem.
The aperture is getting stuck at f22, when attached to the camera.
Everything seems to work smoothly by itself. After I attach it to the camera, if the aperture is set to Auto or f22, it gets stuck. It can't open any wider.
If I attach it while set to f2, it will work at each aperture, up to f22, where it gets stuck again.
I'm guessing this is a lever problem? When I compare it to my other lenses, the lever looks closer to the black bit of metal that sticks up even with it (don't know what that's called). The gap between them is very small.
Any suggestions?
04-09-2019, 02:24 PM - 1 Like   #7
pschlute's Avatar
QuoteOriginally posted by ccbl Quote
Any suggestions?
You could try gently bending the lever . Or best of all just avoid f22. Likely to cause diffraction using that aperture.
04-09-2019, 02:49 PM - 1 Like   #8
If it was just f22 I might ignore it; but the A setting doesn't work either, and I do want that.
I guess I'll have to send it back after all :|
04-09-2019, 07:50 PM - 1 Like   #9
I love that lens.
PENTAX K-S2  Photo
04-10-2019, 05:35 AM   #10
QuoteOriginally posted by Marktax Quote
I love that lens.
Keh had another in stock, so they're exchanging it for me. I'm looking forward to it! I love the sample images I've seen.
04-10-2019, 06:16 AM - 2 Likes   #11
pschlute's Avatar
It gets mixed reviews but i have always liked it.
K1 + FA* 24mm. 1/15 ISO 200 f11
04-21-2019, 02:52 PM   #12
I've had this lens since it''s first availability. Mine is just great. Sharp, contrasty, great colour rendition and free of aberrations and distortions. Perhaps, since it was 'bleeding' edge technology for Pentax at the time there may have been considerable variance in the production.
04-22-2019, 02:48 AM - 1 Like   #13
pschlute's Avatar
QuoteOriginally posted by BillO Quote
Is that where the technicians are constantly cutting themselves on the glass elements during assembly?
05-08-2019, 07:11 PM - 2 Likes   #14
Precisely. Those aspherical elements are deadly!
24mm, af, autofocus, camera, f2, lens, lenses, pentax help, pentax-fa*, photography, reviews, troubleshooting
For Sale - Sold: FA* 80-200 f2.8, FA* 28-70 f2.8, FA* 24 f2, FA 43 f1.9, M 50 f1.7, K-7, AF-540FGZ JerryFu Sold Items 6 02-25-2019 10:47 AM
For Sale - Sold: Pentax FA* 24mm f2, FA* 85mm, 31mm, 10-17mm, D-FA 100mm WR, 14mm f2.8 (reduction) sjwaldron Sold Items 2 11-26-2012 12:05 PM
Pentax 12-24mm vs Sigma 12-24mm & Tamron 10-24mm Comparative Review Adam Pentax SLR Lens Discussion 7 03-23-2012 03:07 PM
All times are GMT -7. The time now is 09:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
