04-20-2019, 10:28 AM   #1
TerryL's Avatar
Jpeg Pixel Size?
Hello,
I am setting up my KP to shoot my Son's track and field events. I will be shooting in burst mode and jpeg. What pixel size should I choose, small or large. I really don't knot the difference. Thank you very much.
Terry
04-20-2019, 11:21 AM   #2
Lowell Goudge's Avatar
Small medium and large are not pixel size but jpeg compression. Jong compression does 2 things, compared to raw.
First it downsamples the colour depth from 12 or 14 bits down to 8. Second, depending on the compression it merges shading and colours of pixels together
This is different than setting the number of megapixels which is also an option available.
04-20-2019, 12:35 PM   #3
As long as you have a fast SD card, using the maximum JPEG quality and resolution settings doesn't penalize burst performance much. So, that's what I'd recommend. Just be sure to disable distortion corrections, as these add a lot of processing time.
04-20-2019, 01:31 PM   #4
TerryL's Avatar
Thank you, Adam. Where do I set it. Small or large. I will make the other setting that you recommend, too. It's the jpeg recorded pixels. Camera 2 Image capture settings.
Terry
---------- Post added 04-20-19 at 01:35 PM ----------
Thank you, Lowell. I still need to know where to set this setting. Camera 2 Image capture settings, Jpeg recorded pixels.
Terry
04-20-2019, 01:41 PM   #5
They are both under the image capture settings:
04-20-2019, 02:41 PM   #6
TerryL's Avatar
Ok, I have it set to L, and distortion correction is off. Anything else? Now can I set it to continuous focus, and increase my focal points, and use a fast card, and burst away. Stop down for goof dof, and increase shutter speed to 500. Will this be a good method for track and field?
Terry
04-20-2019, 02:43 PM   #7
QuoteOriginally posted by TerryL Quote
Terry
Sounds like a plan! The only other thing I'd double-check is that other time-consuming corrections are off, such as skin tone and clarity.
04-20-2019, 04:39 PM   #8
TerryL's Avatar
I sure will, Adam. Thank you so much. This will be my first attempt at sports, so I'm a little nervous about it. I'm more of a set up the tripod, and slowly think through everything for landscapes. I hope the KP serves me well. These shots will be of my youngest Son, so I really want to nail it. I'm just hoping for a few keepers.
Regards,
Terry
04-21-2019, 01:54 AM   #9
pschlute's Avatar
I think you know this already, but as well as continuous focus you need to set continuous shooting in the drive mode.
Have a look in the manual for use of "Expanded area AF" points. This can perform better with moving subjects. Be wary about setting the number of focus points too wide or the camera may be focussing not where you want it. Suggest you try and practice first and see which works best for you.
04-21-2019, 09:27 AM   #10
Seems to me the smaller JPEG file settings are mainly to email images.
04-23-2019, 05:26 PM   #11
TerryL's Avatar
Thank you, Peter.
---------- Post added 04-23-19 at 05:30 PM ----------
QuoteOriginally posted by mikesbike Quote
Thank you, Mike. I set it on L.
camera, compression, focus, image, jpeg, jpeg pixel, pentax help, photography, pixel, pixels, settings, terry, troubleshooting
Pixel shift with pixel artefacts Dericali Pentax K-1 4 07-18-2018 12:57 PM
Lloyd Chambers Prefers Pentax Pixel Shift To Sony's Pixel Shift Fenwoodian Pentax K-1 2 07-16-2018 02:15 PM
Picture file size, picture pixel size, resizeing picture, discussion panonski Digital Processing, Software, and Printing 11 12-01-2016 08:38 AM
Sensor Size and Pixel Size interested_observer Photographic Technique 5 02-04-2012 07:59 AM
All times are GMT -7. The time now is 02:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
