Originally posted by Larrymc Nice vicious little Copper head one of the snakes with a nice un-provoked bite record! You did kill the rascal didn't you??
No, I didn’t...it was just trying to find something to eat. I always leave snake alone. Killing them may do more harm than good.😊
Michelle
---------- Post added 04-22-19 at 08:48 PM ----------
Originally posted by stevebrot I see! It is also likely that the hot shoe spring clip is on the forest floor somewhere.
(Will have to remember that U.S. Camera has these parts lists and diagrams.)
That diagram posted by “Not a Number” is very helpful. I just checked my camera, only two things are missing, one is CNL -D1.7x2.5 screw (broken I assume) and A330 hot shoe ground plate.
Michelle
---------- Post added 04-22-19 at 08:50 PM ----------
Surprisingly, it’s still there! But the ground plate A330 is on the forest floor somewhere....☹️
Michelle
---------- Post added 04-22-19 at 08:54 PM ----------
Originally posted by builttospill Another vote for epoxy, available at any hardware store. There are a few different types of epoxy. Unless you're skilled at things like this avoid the steel putty epoxy, as this is electrically conductive and may act as a jumper between different posts in the hot shoe. If you're concerned about making a mess with superglue, don't get the liquid kind. Get gel or even better, putty epoxy. Rough up the surface on the bottom of the hot shoe, mix the epoxy together and place the putty where in needs to go. Work quickly, as this dries pretty fast.
That’s very helpful! Thank you so much for your advice! Every time when I go to hardware store, I often overwhelmed by so many different types of glue, and too shy to ask for help. That’s why I often avoid using glue...especially liquid superglue.
---------- Post added 04-22-19 at 09:03 PM ----------
Originally posted by Not a Number Part A322 (hot shoe frame) has threaded holes in it. Normally when you tear screws out without unscrewing them you'll either strip the treads in the hole or on the screws or break the screws or all of the above. All the structural screws on every Pentax body I've worked have been steel (stick to my magnetized JIS drivers). The hot shoe on every Pentax body I have is non-ferrous (magnets not attracted to it) - probably aluminum. Aluminum is more likely to strip than steel.
“Not A Number”
You are correct, I just checked the 3 screws with treads (U5), they are still on the camera, and one still have some “copper colored” particles left on the screw. However, the one(1.7x2.5 mm) retainer screw is broken, and A330 hot shoe ground plate is missing too. By the way, that camera diagram is very helpful, thank you very much for sharing!
Michelle
---------- Post added 04-22-19 at 09:08 PM ----------
Originally posted by UncleVanya But his expressed main concern was Macro where I contend there is not a huge value to those features. So maybe his flash is over featured - he could sell it off and buy something simple to replace it if that's his main use. Over time he may refine what he needs and not need the 360.
I love my 360! That’s my birthday gift and I am not selling any of my pentax equipment...(even when they are broken)
---------- Post added 04-22-19 at 09:18 PM ----------
Originally posted by stevebrot It also looks like the body needs the old screws extracted. That is the greater challenge and probably more expensive than getting a replacement hot shoe assembly.
You are right Steve, after re-exam my camera very carefully with the Diagram, I don’t think I have the skill and tools to fix the broken hot shoes. I probably have to take it back to the precision camera in Austin (they are the only authorized Pentax dealer here). I will take this accident as a learning experience. Once it’s fixed, I will get a bracket and flash trigger to protect my equipments.
By the time I save enough money, maybe I will get the new pentax APS-C DSLR camera (maybe in 2020) to replace my k3ii.
Michelle
