05-05-2019, 05:32 PM - 1 Like   #61
K3/2 manual...page 9 X-sync socket (just below GPS button)
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-3-2.pdf
Page 93 shows the dust cover to the socket being unscrewed ...
05-06-2019, 06:41 AM - 1 Like   #62
I don't know what trigger voltage that Centon ringflash has, it is similar in appearance and vintage to my Cobra, I recon it's the same unit, which is under 8V. No doubt you will have tried it out before reading this. The tiny waterproofing cap for the sync socket is easy to loose, be careful and put it away safely.
05-06-2019, 12:23 PM - 1 Like   #63
QuoteOriginally posted by pentasonic49 Quote
4.38V according to this chart..
Photo Strobe Trigger Voltages
05-06-2019, 01:45 PM   #64
QuoteOriginally posted by bobD Quote
Hi BobD:
It's so well hidden! 🤣 Thank you so much for pointing it out for me...
Michelle
---------- Post added 05-06-19 at 03:49 PM ----------
Hi Pentasonic49:
You are right, it's so small, looks like something that would just disappeared if I put just it in my pocket😂...I will put it into a small Ziploc bag, then place it in my K3ii's original box.
Thank you!
Michelle
05-06-2019, 02:08 PM   #65
There's a bit of learning to do with a corded flash, you probably have to set X on the function dial, or shutter speeds below 1/180. Lots of test shots indoors are needed to get the hang of it . Googling the name and number should get a pdf of the instructions if you don't have them. The ring flash is less powerful than what you are used to and the auto function is less sophisticated.
When you take the top off of the other camera, there will probably be two screws hidden until the flash is raised which are obviously not on the K3ii. Because the screws are so small, when re assembling, just tightening them between thumb and forefinger should be sufficient.
05-08-2019, 11:07 AM   #66
carabez's Avatar
QuoteOriginally posted by Pufferchung Quote
That video is awesome! I think I can take the screw out myself.
If the flash hot shoe is NOT riveted (it is screwed), you could get another cheap camera to get the spare from.
I don't know if the *ist model will fit.
Pentax * ist DS 6.1MP Digital SLR Camera Body #740 | eBay
Pentax K3 Camera Body--Please Read 27075129252 | eBay
05-09-2019, 10:55 AM - 1 Like   #67
Carabez, in post #55, Pufferchung mentions having a broken KS2 which she can practice dismantling and have a source of the hotshoe and screws. I hope she will soon be able to give us some good news regarding the K3ii.
07-06-2019, 06:20 PM   #68
I took apart my KS2 and omg it's really complicated! So I decided to get a PC male to hot shoe sync cord and Holgon RF-50 Macro-lite Ring Light Flash with Synch Cord.
adapter, af360fgzii, broken hotshoe, cable, camera, cord, flash, forest, hotshoe, hotshoe flash, ii, k3ii, macro, money, moths, nature, pc, pentax, pentax help, photography, precision, repair, shoe, socket, troubleshooting, x-sync
Help! K1 hot shoe came off (warning: k1 gore) bigoak Repairs and Warranty Service 55 12-07-2017 12:43 AM
Pentax K3II above the serial number for power off issue has had power off issue Azhure Pentax K-3 & K-3 II 3 04-10-2017 03:23 PM
Santa came early - new 645Z and K3II are here! mikeSF Pentax DSLR Discussion 38 12-11-2015 10:09 PM
HELP! Pentax Me super filmd rewind crank came off, cant get it back on kawehna Film SLRs and Compact Film Cameras 7 04-01-2013 03:54 PM
Wanted - Acquired: Wein Safe Sync hotshoe to hotshoe adapter gabriel_bc Sold Items 1 06-13-2011 05:01 PM
All times are GMT -7. The time now is 05:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
