Originally posted by TaoMaas
This is something I thought about after having replied earlier. For the first half of the time I shot film, I used to load film the way most folks do...drop the canister in the camera, then pull the leader across to the take-up side. Seems like it was a workshop where I learned to switch up that process...get the leader started securely in the take-up spool, then pull the canister across the back of the camera and drop it into place. There's also usually enough film wound onto a canister that you can let it make a full wrap or two around the take-up side before finishing your loading process. That way, you don't have to guess whether it's caught or not.
The only problem can be if one doesn’t have any young to push into the slot.
Sometimes typos are logical, but quite absurd.
---------- Post added 04-28-19 at 11:17 AM ----------
Originally posted by TwoUptons
If I’m not developing film myself, I’m a lot less likely to leave the leader out when I rewind...
And it’s still a half-habit to lightly tighten the rewind knob after a couple of shots, just to make sure...
I’ve almost always put the canister in first and pulled the film over. It helps me make sure it seats.
I think most/some of the MZ/ZX family of cameras have a custom setting to let you leave the leader out if you want. I thought the -5 was one of those (I think I used to do that when I had one).
-Eric
It’s a lot easier to extract the film if the tongue is sticking out, and the light seal works better with film in it. I always left the tongue out but would either tear the tip off or fold it over to indicate the film was used. Cameras that reversed the film on the take-up would generally crease the tip anyway.
