Originally posted by Swift1 But this will occur when you inevitably rewind the finished roll. If this caused scratching then every camera would scratch the film every time it rewinds.
No, No, No.
Did you not understand my first sentence???
When you 'tighten' the roll, the beginning of the roll is held firmly by the advance spool - so it can tug on the film spiral; as you rotate the crank, each complete turn adds an additional spiral into the same length of film, forcing the spirals closer and closer together {which is basically why you are doing this}. If you do this long enough, they will be forced to rub against each other.
When you rewind the roll, the advance spool is allowed to rotate freely until the film just pops off; there is never a tug on the film spiral. Each complete turn does add an additional spiral, but it also increases length of film in the spiral; size of the can does constrain the film, but film manufacturer designed the can so that the spirals never get dangerously close.
added:
When tightening the film, spirals will get closer and closer and closer - only limit is having each spiral is pressed firmly against its neighbors so it can't get any closer.
When rewinding the film, spirals may get closer, but this will stop when all film is in the can - manufacturer has designed can so there is plenty of space.
