05-25-2019, 05:42 PM   #16
TerryL's Avatar
QuoteOriginally posted by jpzk Quote
Hi everyone.
I have been using my DA*300/4 for many years (seven to nine years now I think) and I have never encountered a problem with it ... ever.
This morning I was out doing some birds of prey birding and all of a sudden, this happened:
Pressing the AF (top front - I don't use the back AF button) - lens mounted on my K3 as usual - : I can "hear" the SDM AF kicking in but within a few seconds the obvious screw drive AF kicks in !! I sure could hear this buzzing typical of the screw drive AF.
This goes on back and forth between the SDM vs. screw drive a few times then it stops and goes back to SDM only.
Another thing that happened while the screw drive AF was active, is the "continous AF" while the camera is set to single AF only.
So I turned the camera off, started it again : same thing but only once.
Then: turned the camera OFF, removed the battery - reinserted the battery, turned camera on: all is fine for a few shots but it did happened once more.
Even when the SDM AF was "supposedly" working fine, about 50% of my shots were blurred. Even those shots of stationary subjects.
Note that the lens switch was on AF; I had verified this.
So ... big questions:
1. Is this a sure sign that my DA*300/4 is dying?
2. Why would the screw drive kick in?
3. Has the camera having anything to do with this?
Any help/advice/opinion would be tremendously welcomed.
Thanks !
If UncleVana will take it, you can rest in peace. He fixed my DA 200, and I now absolutely love it. The screwdrive is fast and accurate. I'll do the same if my DA 300 acts up.
05-25-2019, 07:23 PM   #17
Ooh! Shiney! Me Want!
monochrome's Avatar
Sounds like one of those wired electrical conflicts often reported when battery voltage is low and/or thrtr’e some conflict with the grip.
05-30-2019, 06:27 AM   #18
UncleVanya's Avatar
QuoteOriginally posted by TerryL Quote
I do take the DA 300. Thanks for the plug! If I recall the op got his legs working again so conversion may not be needed.
06-20-2019, 06:13 AM   #19
jpzk's Avatar
Seems like it ... the camera has been "performing" normally since I made sure to have the grip power OFF and the batteries fully charged.
Then gain, what will happen when I turned this grip ON ? (I haven't had the need to have it powered up lately).
---------- Post added 06-20-19 at 09:14 AM ----------
See my reply above.
06-20-2019, 06:22 AM   #20
monochrome's Avatar
See my reply above.
Make sure the ON switch is correctly aligned in it’s detent. Misalignment seems to cause problems.
06-20-2019, 06:39 AM   #21
normhead's Avatar
I have similar problem with my DA*200 when it's cold out. If the battery is low it doesn't have enough power to run SDM. It works properly only with a freshly charged battery if it's cover than -10ºC.
af, battery, battery voltage, camera, check, converter, da*300/4, drive, focus, grip, pentax help, photography, post, screw, sdm, shots, switch, troubleshooting
Could you please tell me the mount of this lens mars76 Pentax SLR Lens Discussion 7 12-03-2018 12:50 PM
Nature Tell me, am I a handsome fellow, or what? Which side do you think is my good side? ToddK Post Your Photos! 7 06-23-2018 06:17 AM
My site: tell me what you think soccerjoe5 General Talk 20 02-03-2009 09:05 PM
My first attempt at IR, tell me what you think? skid2964 Post Your Photos! 11 09-15-2008 06:26 PM
JACKPOT!! please, please tell me what to pay for these unused classics in an attic. 123K10D Pentax SLR Lens Discussion 28 01-20-2008 09:21 PM
All times are GMT -7. The time now is 02:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
