Originally posted by Perfessor5646 The knurled wheel on the battery grip will not turn in either direction. There is a minuscule amount of vertical flop. Being a slender senior citizen and already losing upper body strength, I cannot imagine that I over tightened it to the point I nor two former marines cannot turn it.
Yup, you've over tightened it.
Originally posted by Perfessor5646 Righty tighty, lefty loosey. Correct? As best as I recall there is no other locking mechanism.
Yup.
Originally posted by Perfessor5646 I’m assuming traditional techniques for removing stubborn lids, running it under hot water faucet or tapping it on the edge of a counter are not good ideas. Nor is a liberal application of WD40.
Indeed.
Originally posted by Perfessor5646 Do y’all think this needs to go to an authorized service center? Both pieces are out of warranty so there is no deadline
Nope. Just take a deep breath and remember it's lefty loosy when looking at it from below. Then, take something like a screwdriver with a bit of cloth around the tip and carefully push in the ribbed knob surface in the direction to loosen. A little bit at a time, and before you know it, it will be loose. Take care as to not slip and don't gouge a groove int he side of the camera or the grip.
