last frames i took yesterday were accompanied by weird, harder than usual sound, that was somehow more stretched. the same was happening on several single occasions few weeks before yesterday, but only for one or two shots. so, shutter stopped to respond, there was no more light at the end of viewfinder, then i switched camera off to change the battery because indiacator still showed that newly bought & fully charged for the first time fujitsu lsd were still full after 600 photos taken with manual lenses only, no long exposures this time and of course no inbuilt flash used (blasphemy!
), but since standard battery was usually shown almost empty just after 50 shots, it was natural to consider that indicator is incorrect again. after battery was changed the screen still was functioning, however shutter remained unresponsive. took the lens off and there was mirror locked up. then after another switching off/on even screen was dark. last 3 shots were black (didn't check that immediately, only after i copied files into computer).
bought it locally for 300 euros a year ago, it was looking good, seller said it's used just a little, but after got to know here at pentaxforums how to check shutter count, it was a bit over 50k, then also death of the green solenoid was discovered, but that was not a problem as i used only lenses with aperture ring and mostly manual focus. until buying DA 12-24mm F4 ED AL [IF] few months ago i had no idea that solenoid isn't functional.
for the archives - total shuttercount for is 56'463 frames + 3 black ones.
one of the good shots from last 24 hours of this camera:
6 / beware of the auto! | lens used - smc pentax-a 1:1.7 50m? | Flickr
