05-09-2019, 08:44 AM   #1
DA 300 mm with screw drive AF, Camera doesn`t detect focus length
Hi,
I got a DA 300 mm f4 which has been changed to screw drive AF. The Cameras (KP, K01) don`t detect the right focus length. The KP detects 42 mm, the K01 27 mm. KP overexposes around 2 stops, the K01 underexposes around 1 stop. It reads the aperture with 1 stop to wide open.. Does anyone have an idea about what can be done about this ?
05-09-2019, 09:01 AM   #2
Have you tried to clean the contacts?
05-09-2019, 09:06 AM   #3
amateur dirt farmer
pepperberry farm's Avatar
is this a new problem or has this lens always had this issue?
05-09-2019, 09:11 AM   #4
SME
well, I just bought it. It was used on a KP without any issues (as has been told), and the seller confirms that the contact worked well on his camera. The price was heavily reduced due to the change in AF mode. The optics itself appear flawless.
05-09-2019, 11:32 AM   #5
It should not overexpose by 2 stops, even if the FL is being misinterpreted as 42mm. In an AE mode, it would set a lower shutter speed, but also an appropriate aperture to match for the lighting at hand.
What other lenses do you have, and do they function normally?
05-09-2019, 11:56 AM   #6
SME
Yes, the other lenses function normal. I just found out, that the underexposure on the K01 is not consistent, sometimes it exposes correctly, but it never reads the 300mm and ir reads aperture down til 2,8, though it`s a 4,0 lens.. My KP is with my girl friend at the moment, so I cant doublecheck right now..
05-09-2019, 12:16 PM   #7
UncleVanya's Avatar
Sounds like either a problem with the lens contacts. It could be a problem with the internal electronics also. Double check that the contacts are clean.
05-09-2019, 12:20 PM   #8
SME
yes, they are clean, and all other lenses connect fine
05-09-2019, 12:22 PM   #9
UncleVanya's Avatar
QuoteOriginally posted by SME Quote
Then I'd guess the lens internal electronics are damaged.
05-09-2019, 12:36 PM   #10
SME
QuoteOriginally posted by manishved Quote
yes, they seem fine
---------- Post added 05-09-19 at 09:42 PM ----------
Do you have any advice who can check this ?
05-09-2019, 12:49 PM   #11
pschlute's Avatar
If I were you I would return the lens.
05-09-2019, 12:51 PM   #12
SME
got it for 250 EUR; would you still return it ?
05-09-2019, 01:01 PM   #13
jab2980's Avatar
I would without hesitation pay 250 EUR/280 USD for that lens as you've described it. However, if the seller did not describe this condition accurately then I would seek some sort of compensation.
05-09-2019, 01:04 PM   #14
pschlute's Avatar
It has been converted to screwdrive by someone who I do not know; it does not report correct focal length; it does not expose correctly; and it reports incorrect aperture.....yes I would return it.
05-09-2019, 01:38 PM - 1 Like   #15
Since the lens doesn't have an aperture ring, problems with exposure will probably cause you a lot of headaches later down the road. Despite the low price, I would either seek compensation or return it. One option would be to get it repaired. Even then you'd be getting a great deal!
af, camera, da 300 da screw drive, da 300 mm, drive, focus, k01, kp, lens detection by camera, mm, mm with screw, pentax help, photography, screw, screw drive, troubleshooting
DA *300 F4 screw drive? slip Pentax SLR Lens Discussion 2 05-28-2016 09:48 AM
For Sale - Sold: Brand New FA 31 mm, FA 77 mm, DA* 60-250 mm, DA* 300 mm ppkkcao Sold Items 14 11-02-2014 08:42 PM
Why can't screw drive be as fast or quiet as wave drive? vimbuza Pentax DSLR Discussion 13 12-08-2013 10:36 PM
Screw driven AF cameras. More high end = better screw drive? Reportage Pentax DSLR Discussion 13 09-01-2011 08:38 AM
All times are GMT -7. The time now is 02:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
