05-18-2019, 07:43 PM   #1
Shutter/Mirror issues for K3ii
My K3ii is just over a year old and has performed well up until now. A week ago, I wanted to get some pics of my granddaughter in her marching band exhibition. The first picture worked as usual but after that, there was an extra noise coming from inside the camera, and the picture came out black on the review. It continued this way for the rest of the shoot, and it is still doing it. I removed the lens and watched inside as the shutter was activated., I have sent a video showing what happens. Hopefully it plays. Make sure you have volume turned up. It's very frustrating, and I no longer want to use it until I get this resolved. Any info you can send to me will be greatly appreciated.
05-18-2019, 07:46 PM   #2
MarkJerling's Avatar
I can't get that avi to play Dave. Would you like to try to post it to Youtube and post the link here?
05-18-2019, 07:52 PM   #3
Otis Memorial Pentaxian
RobG's Avatar
I think people are calling it mirror slap. Have you upgraded the firmware? Tried taking out the battery? My K3 has done it a couple of times, but returns to normal after a second or two.
05-18-2019, 08:04 PM   #4
I can't play the video either. looks like the file has a problem. If you can upload to youtube and give us link here, we should be able to see what is it.
if it is a mirror lock up problem, you won't be able to take a photo and it could be fixed by remove battery. However from what you said it sound like you still can take photo? Not really sure what it is you are having.
by the way, On my K3, some Pentax's battery cause mirror lock up problem. I avoid using that battery.
Update firmware to the latest one help camera return mirror to normal position when turn camera on/off. otherwise, as mentioned, remove the battery.
05-18-2019, 08:36 PM   #5
I was able to open the file using VLC. No audio, though
05-18-2019, 11:06 PM   #6
QuoteOriginally posted by davefraser54 Quote
What you are describing sounds like the detect/recovery behavior included on the v1.11 firmware update for the K-3. The intent of the patch was to detect the so-called K-3 runaway mirror problem* when it occurs. While the firmware patch did not correct the problem, it helped avoid damage to the mirror mechanism until a repair could be done by aborting the exposure sequence with a resulting blank frame. Ricoh/Pentax also provided an actual fix for the problem itself, but which required installation of new low-level firmware for the mirror controller board. The fix was available as a warranty repair or for a fee for cameras already out of warranty.
That being said, the issue was resolved in production for all K-3 produced after fall of 2014. I don't recall whether anything similar has been reported and confirmed in the K-3II. If your K-3II was purchased from an authorized dealer in Canada, it should still be covered by the two-year Pentax Canada warranty. They would be your best resource in getting a proper diagnosis and repair done.
* The runaway mirror problem was distinct and different from the "mirror flap" (aka "mirror flop") issue reported on some K-5 and lower-model Pentax bodies (e.g. K-r). The mechanism on the K-3, K-3II, and KP is dissimilar to that on those cameras and has never shown that problem.
05-19-2019, 06:41 AM   #7
RobG's Avatar
Ah. I didn't know that. In all the time I've had the K5iis I don't think it's had an issue, and the "runaway" mirror behaviour has only happened a couple of times, I think, and was easily resolved by cycling the power. I didn't know that there was a "real" fix for the problem, so thanks for mentioning it! Maybe I should use the K5iis for a while and send the K3 back for repair...
05-19-2019, 10:05 AM   #8
Thanks for the replies. To start the process of elimination, I have 5 batteries and the problem exists with all of them. I checked the firmware and I have the latest version (1.10). I will try to upload the video to YouTube and post the link.
The camera was purchased from Amazon. I will check to see if they keep the two year warranty.
I will try to post again sometime today.
---------- Post added 05-19-19 at 11:32 AM ----------
Here is the link to YouTube -
05-19-2019, 11:07 AM   #9
They are authorized in the U.S. and should be in Canada. Check with Ricoh/Pentax Canada. They will know.
I watched the video. This does not look to be something for which there is a user work-around.
05-19-2019, 12:49 PM   #10
Thanks, Steve. I'll post any pertinent details if and when I get this solved.
camera, k3ii, link, mirror malfunction, pentax help, photography, picture, post, shutter malfunction, shutter/mirror issues, troubleshooting, youtube
K3ii - SD card issues jmerchant Troubleshooting and Beginner Help 10 01-01-2019 03:41 PM
K3II - Mirror Stuck sutherland Pentax K-3 15 07-17-2018 08:36 AM
New K3II mirror runaway still occurs? Chris Mak Pentax K-3 24 06-29-2018 06:07 PM
mirror flop? shutter issues, vibrations... wes k Pentax K-r 23 08-19-2015 05:38 AM
S3 and S1a shutter & mirror return issues? 35mmGun Pentax Film SLR Discussion 8 08-15-2011 05:43 AM
All times are GMT -7. The time now is 10:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
