Originally posted by landofcourtness Hello,
I'm not sure how to describe this or where this goes...
But a couple of days ago I was shooting a Lacrosse game with a Sigma 70-200 lens on my Pentax K-1 and a different lens on my K-3, when it began to rain (not the hardest rain/downpour, but it was pretty steady). Since that time, my K-1 now loses contact with any lens that is attached (F-stop flashes), but it rarely happens. It seems to happen only when pointing directly down or up... and as the camera is moved from one position to the other. As long as its not at the up/down configuration, the camera operates like normal (or as far as I can tell, able to set all 3 settings and IQ seems fine). It rarely happens to the point where it interferes with anything, but enough to notice or be annoyed. Also, when I go to different or shorter focal lengths, it also returns to normal. Meanwhile my K-3 (which also had a SIGMA lens for some time) is perfectly fine. I originally thought it was the lens, but then realized that it happens with every lens that is attached.
It's strange because even caught in any weather, I've never had any issue with a Pentax-anything making it through. Normally I tell everything that Pentax is the definition of durability. I was just wondering what you think the cause might be? (I was thinking maybe a stabilization thing...) and then if there is a remedy or what it might take to fix?
Feel free to ask any questions, as I realize that this description may not be the best.
A few things to point out
As others have said, it might be the camera or lens is wet , even after the fact.
BUT, I dropped my K1 with a sigma 70_200 plus 2x teleconverter and it lost all aperture contact. Before this incident, the lens and tc combo had been a little intermittent on all my bodies , but the bit drop, hitting the lens hood first finished it.
In the end I discovered the lens mount on the teleconverter had bent enough to lose contact, I suspect it had been slightly deformed over the 15 years I have had the combo. Luckily a replacement tc fixed all of it.
So check closely your lens mount, it may have been an issue growing for a while.
I noted a suggestion to check the mount screws for tightness, I think it might be on the right track
