Originally posted by Jome Again, thank you to all of you.
I will wait a while to either acquire one of those cactus or find a second hand 360 or (wish I will find) a 540.
Kind regards.
J.
If your main goal is to use HSS, I would higly recommend the radio trigger or a cable over a two flashes optical trigerring. Because, usually, HSS is needed when there's a lot of ambient light, often outside in daylight. The problem being with this high level of ambient light tends to blind the optical trigerring making the whole sytem unreliable, HSS or not. If the deported flash sees even a hint of direct sunlight, there's a good chance it will not trigger at all.
