Originally posted by Proudmale I would have thought that something like that would be standardized across all modern Pentax cameras. If they are different, does anybody know where I can get an adapter?
With two exceptions, Pentax has standardized.
Your K-3 shares the same cable remote specification as all other Pentax dSLRs that came before it; that being a 2.5mm, 3-conductor (two band, TRS) phone jack. If the Vello does not fit your K-3, it is probably a question of clearance that is likely a problem with the other models as well. The K-70 and KP (the two exceptions) use the same simple protocol as the K-3, but combine the microphone and wired remote port using a 3.5mm, 4-conductor (three band, TRRS) jack. There are several threads regarding options other than the Pentax-brand cable. The gist of the solution is to use a 3.5mm --> 2.5mm adapter. The best thread I am aware of is this one where the conductor mappings are diagrammed out and where adapter options are explored.
About the wired remote control. - PentaxForums.com
