06-17-2019, 02:06 PM   #1
How to connect to pc
Hello I've recently bought an old Pentax IST D's it seems to work fine but when I plug the USB lead into the camera and pc and turn on the camera the pc doesn't see the camera. Any advice please would be great
06-17-2019, 02:20 PM   #2
Not a Number's Avatar
Without downloading the user manual I would say try going into the setup menu and try changing the transfer mode settings.
You can download the user manual here (see discontinued models):
Operation Manuals Download : Support & Service | RICOH IMAGING
06-17-2019, 03:19 PM   #3
Just1MoreDave's Avatar
Try this:
[Set-up] -> down to second page -> [Transfer Mode] -> [PC]
06-17-2019, 03:42 PM   #4
paulh's Avatar
If none of those suggestions work, try a usb card reader (SD reader for *ist DS, CF reader for *ist D).
06-18-2019, 08:51 AM   #5
Thank you very I'll try tonight
06-18-2019, 11:48 AM - 1 Like   #6
noblepa's Avatar
I recommend that you forget you ever heard of the USB connection between your camera and your computer.
I say this because the USB connector in the camera is mounted to the motherboard of the camera. Unfortunately, in most Pentax models, the only thing that physically secures the connector to the mobo are the solder joints to the copper trace lines on the phenolic plastic mobo base. This is a very (VERY) weak physical connection.
The least little bit of lateral force when connecting/disconnecting the USB cable can easily tear those very thin copper traces. The only practical repair is to replace the motherboard, which is very, very expensive, especially for an older camera.
Just remove the SD card from the camera and put it in the computer's SD card slot. It probably has a faster transfer rate, as well.
06-18-2019, 12:13 PM   #7
If your computer has no SD card slot, get a card reader- they are inexpensive, and they work very well. They are also relatively small and portable, so you can take it about and also download photos taken with them onto a friend's computer as well as your own. They would then be full size files with full quality, unlike those sent via e-mail.
06-18-2019, 06:07 PM   #8
QuoteOriginally posted by noblepa Quote
...Just remove the SD card from the camera and put it in the computer's SD card slot. It probably has a faster transfer rate, as well.
You get to take advantage of recent technology improvements that way.
The DS has such small files compared to current cameras, they seemingly transfer at light speed.
06-19-2019, 03:10 PM - 1 Like   #9
I've ordered a card reader and ditched the usb lead. Looking forward to see the pictures and how they compare to the finepix
06-19-2019, 10:24 PM   #10
QuoteOriginally posted by Scott pascall Quote
The Fuji Finepix, depending on the age and model, can deliver good, sharp images. But the sensor size is rather small, and not capable of quality imaging at higher ISO settings than 200 or 400. With the DSLR, you can also mount various lenses, some of which are of superior performance including low light capability. For example, a good used pentax F or FA 50mm f/1.7 or a new DA 50mm f/1.8 will be great for taking portrait photos as well as fine low light scenes.
camera, pc, pentax help, photography, troubleshooting
Transferencia de fotos a PC (Transfer photos to PC) Cristian Albornoz Visitors' Center 3 08-20-2017 06:34 PM
The pc connect port has fallen into my k100d Arizis Troubleshooting and Beginner Help 3 01-09-2012 11:22 PM
K200D not able to connect to PC through USB cable ducdao Pentax DSLR Discussion 15 05-22-2011 11:53 AM
How get multiple PC connections using one PC jack? davidstone Pentax Camera and Field Accessories 3 10-01-2009 05:19 PM
Question PC - error / issue with Modern Skin. NOT SITE MY PC HELP!! vievetrick Site Suggestions and Help 2 11-06-2008 11:24 AM
All times are GMT -7. The time now is 12:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
