Spotmatic F - meter needle issue
Hello everyone,
I have an old Spotmatic F which I bought around two years ago or so. Doesn't use it much these days, but anytime I did in the past, everything was smooth and accurate. Recently I discovered a strange issue - meter needle shows accurate reading for every shutter speed except 1/1000th, for which it spikes up like in 'B' mode. The shutter itself runs fine and this speed. The needle behaves this way regardless of metering method; both stop down and open aperture yield same results. When not metering, needle stays in the middle.
Honestly I can live with that, but I'd like to know whether this issue a) has easy fix b) will develop to something more serious if left untreated.
All the best
