06-30-2019, 02:45 PM   #1
How would you go about proving that your IBIS wasn't working?
So I have a Pentax KP which I quite enjoy. However, I rarely notice much in the way of shake reduction when taking shots with the SR on versus off. Is there some foolproof way to determine that in fact the SR is functioning? I don't see any error messages or anything... it's just that the purported effect doesn't seem to work in this case and I don't think I have shaky hands or anything. I think back when I shot with the K50 it seemed like it had more of an effect. I'm willing to chalk it up to using a heavier camera, I was just curious if there was a method of testing it besides side by side shots.
06-30-2019, 02:51 PM   #2
QuoteOriginally posted by selfnoise Quote
Not sure if the KP is different, but if you go into live view you can see it operate. Another thing is to check the exif for the image file. That will tell you whether it is actually enabled.
06-30-2019, 03:03 PM   #3
What I would do to test that, similar to how some reviews test any such system: pick a focal length and aperture.
Start from high ISO and relatively high shutter speed (1/fl). Take 5 or so shots, definitely more than one, and lengthen the shutter. That's why you'd start from higher iso, to have room to lower the shutter speed.
Keep doing so until none of the shots are in focus. Enable Sr at that speed and compare results.
It's important to compare multiple shots because your hands don't move the same for every shot.
---------- Post added 06-30-19 at 06:06 PM ----------
Perhaps the increased resolution allows you to notice smaller movements during exposures, although I'd think the improved sr system ok the kp would make up for that?
06-30-2019, 04:06 PM   #4
swanlefitte's Avatar
Many times SR will cause blur on a tripod but not guaranteed. If you notice a difference with it on or off you know it's working. You can't use the delay with SR so you need to use a remote shutter activation.
06-30-2019, 04:14 PM   #5
ZombieArmy's Avatar
QuoteOriginally posted by derekkite Quote
Yes, SR is fulltime active in live view on the KP unless you turn it off.
06-30-2019, 05:06 PM   #6
I guess I don't really understand what you mean by it being "on" in live view. Do you just mean the little icon? Is there some way to observe it operating while in live view?
06-30-2019, 05:16 PM   #7
Not sure about the KP, but on the other bodies I've owned, you can hear and feel it.
06-30-2019, 05:22 PM   #8
ZombieArmy's Avatar
You can see it working in live view. If you do sudden movements or shake it around you can see the SR trying to compensate.
06-30-2019, 06:25 PM   #9
Huh, okay. I tried panning around in Live View with SR on and off and didn't really notice any difference. But honestly I don't know what I'm looking for. The KP's live view is so smooth regardless that it's hard to say.
06-30-2019, 06:31 PM   #10
ZombieArmy's Avatar
Look at the screen and quickly move the camera in small circles. If it only appears the live view is going up and down the SR is compensating for the movement on the x axis.
06-30-2019, 08:12 PM   #11
QuoteOriginally posted by ZombieArmy Quote
Ah ok! Yes, something is definitely happening, I can hear it and I notice the behavior you are talking about. So I guess it's working! Thanks.
06-30-2019, 10:22 PM   #12
@selfnoise: panning may not be the best action to check for SR since the camera detects that you are panning and temporary disables SR for this shot.
06-30-2019, 11:23 PM   #13
Fenwoodian's Avatar
Here's a quick and easy test. Just take a Pixel Shift image. The same mechanism that does IBIS moves the sensor for Pixel Shift. If you get a normal Pixel Shift file (insane resolution), then PS is working, and chances are pretty good that IBIS is working too.
camera, effect, pentax help, photography, shots, shutter, sr, system, test, troubleshooting
About IBIS - Which company started IBIS in DSLR's ? Curiosity question. jpzk Pentax DSLR Discussion 30 06-13-2019 04:56 PM
In case your LBA wasn't bad enough... Jeff Pentax SLR Lens Discussion 3 05-03-2019 01:23 AM
Would you go to the Color Run with your Pentax WR gear? mellowyeahlow Pentax K-30 & K-50 18 07-27-2015 10:52 PM
Green button wasn't working on k50 Another dyemention Troubleshooting and Beginner Help 4 03-02-2015 03:10 PM
Nature Ibis, Ibis, everywhere photolady95 Post Your Photos! 9 05-11-2011 08:38 AM
All times are GMT -7. The time now is 01:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
