Originally posted by LaHo Hi Geghani,
There is no setting in the camera for the number of frames. The number of frames is determined by the film back. There is one marked 220 for 220 film. This takes 30 frames on the Pentax 645 (16 frames on the 645N and 645N II). And there is one marked 120 for 120 film which takes 15 frames (16 on the 645N and 645N II), When the camera reaches the end of the film, you will hear it winding on to the end of the film.
I you happen to use 120 film in the 220 film back, the automatic advance will just go on past 15 (or 16).
It sounds as if you used a 120 film back for the first two rolls and a 220 film back for the next three rolls. That would account for what you have experienced.
BTW, as 220 film is rare these days, you can convert a 220 film back to 120 by removing a small plastic piece between the two metal spool hinges and turn it around. It is held in place by two small cross head screws. On 220 film backs it is mounted with a blunt end facing outwards, and on the 120 film backs it is mounted with a pointed end facing outwards. That - and the designation 120 or 220 - is the only difference between the 120 and 220 film backs, as far as I know. The pressure plate is the same.
I have converted several 220 film backs this way and used them with success on my Pentax 645N cameras.
Thank you for th er idea of 120/220 back conversion!
