Originally posted by Bigginge1976 are there any apps/remotes/cable releases the work with the K-S2?
Welcome to the Pentax Forums!
Here are the talking points:
- The K-S2 does not have an external port to support a wired intervalometer, so that option is off the table
- The built-in intervalometer does not support exposures longer than 30 seconds or arbitrary exposure times at interval
- The K-S2 does support IR wireless remote. With appropriate IR transmitter, it is possible to do intervalometry through that interface, though with significant battery draw while the IR remote mode is active. Supported features (max/min times, ramping, etc.) depends on the software used.
- I am unaware of whether Image Sync provides expanded interval exposure features beyond the camera-supported drive modes. If so, it is undocumented.
I have personally used the IR blaster on my Android phone to do B-mode* interval work with the IR remote feature of my K-3 (K-S2 should be similar) with the free DSLR Remote app by bitshift. It does not allow programmed ramping, but does allow arbitrary exposure times up to 99hr, 59 min, 59 sec in one second increments.
Good luck!
* Depending on transmitter hardware/software, it may be necessary to configure B-mode to work in "press to start...press to stop" mode (menu --> C1 --> 7. Bulb(B) mode options: Type 2)
