07-09-2019, 09:16 PM   #1
PROBLEM WITH NEW 55-300 mm f/4.5-6.3 PLM lens
I have just bought a new Pentax 55-300mm lens and cannot get it to focus at all. Because it has a new kind of connection, it was necessary to download the latest firmware first. I did that, and must assume the download was successesful because it went through all the right stages. (The Ricoh instruction is to check which version is installed by going to set-up menu #4, then choose 'Firmware Info/Options' . My camera does not offer that option under set-up menu #4 or 1,2, or 3. So I must assume the download was without mishap.
The new lens came without any kind of instructions and all I get is a very much out-of-focus image. When I try firing the shutter, I get an error message saying that I should set the zoom barrel where the shutter will fire. NONE OF THIS MAKES ANY SENSE TO ME. P{resumably, the auto-focus has to be activated somehow.
Can anyone help, please? Many thanks.
07-09-2019, 09:25 PM - 1 Like   #2
luftfluss's Avatar
What camera model?
The lens is a retractable design. Have you extended it before attempting yo use it?
HD Pentax-DA 55-300mm F4.5-6.3 PLM WR RE Review - Introduction | PentaxForums.com Reviews
07-09-2019, 09:46 PM   #3
Does the zoom ring move? If not, it's in travel position, there's a small round button on the zoom ring, hold that and rotate the ring.
07-09-2019, 09:46 PM   #4
QuoteOriginally posted by 3party Quote
On some models, hold down the menu button while turning the power on.
07-09-2019, 09:59 PM - 2 Likes   #5
It's a retractable model. You have to turn the zoom ring to 55mm or beyond (with the help of a button on the barrel) to extend it first. This will make it ready to work.
07-10-2019, 12:06 AM   #6
This lens works just like any other lens as far as operation goes, with the caveat that it needs to be extended first (as described above) and that any focusing, even manual, requires power.
The most likely explanation is that the firmware update was not installed. You can check your current version by pressing and holding the menu button while turning on the camera. This version should match the version of the update. If it doesn't, reattempt the update and follow these instructions:
Pentax Firmware Update Guide - Tutorial Videos | PentaxForums.com
Also, what camera are you using?
07-10-2019, 01:13 AM - 1 Like   #7
As above, the firmware updates seem to catch some people out (it would've done for me had I not read up on it first).
Disclosing what camera you're trying to marry this lens to would help people out for sure.
07-10-2019, 01:33 AM - 1 Like   #8
Not a Number's Avatar
The OPs profile says they own K20D,K-5 and K-3. I'm guessing it's the K-3 in question since the other two do not support KAF4 lenses.
07-10-2019, 05:31 AM   #9
Mine is starting to intermittently fail to focus. Any similar experience?
07-10-2019, 05:53 AM - 1 Like   #10
Journeyman Cat Wrangler
SSGGeezer's Avatar
QuoteOriginally posted by Marktax Quote
Gently clean all your contacts on the camera and the lens. Detach and re-attach, then check for functionality.
07-10-2019, 08:28 AM - 1 Like   #11
rogerstg's Avatar
QuoteOriginally posted by BarneyL Quote
That would be my guess. Specifically the warning on my KP is: "Shutter release is disabled. Ensure the zooming index on the lens is set to a position that permits shutter release"
Press the button on the lens located between the 70 and 100 and twist clockwise.
07-10-2019, 12:54 PM   #12
I have the little DAL 18-50mm f/4-5.6 DC RE which is not PLM, but works the same way as to being non-functional in the REtracted position.
07-11-2019, 12:50 PM   #13
QuoteOriginally posted by MetalUndivided Quote
Thanks, but nothing makes the AF work.
I will call Pentax.
---------- Post added 07-11-2019 at 12:50 PM ----------
QuoteOriginally posted by mikesbike Quote
I will call Pentax.
---------- Post added 07-11-2019 at 12:52 PM ----------
I will call Pentax.
07-12-2019, 11:46 AM   #14
Please keep us posted on the status of this problem.
55-300 mm f/4.5 - 6.3, af, camera, download, lens, menu, mm f/4.5-6.3 plm, pentax, pentax help, photography, pm, position, post, set-up, shutter, thanks, troubleshooting
55-200, 55-200 WR, 55-300, 55-300 PLM, etc, which telezoom I should get? Bui Pentax SLR Lens Discussion 67 06-25-2018 08:15 PM
DA 55-300 vs 55-300 PLM John A. Pentax SLR Lens Discussion 18 11-03-2017 06:18 AM
55-300 PLM or non-PLM version to K-1? Vignetting etc? HankVonHeaven Pentax SLR Lens Discussion 7 01-29-2017 09:54 AM
18-135 or new 55-300 PLM as an WR upgrade for old DA 55-300 - HELP :) gelokrol Pentax SLR Lens Discussion 6 12-15-2016 11:53 AM
For Sale - Sold: Brand New FA 31 mm, FA 77 mm, DA* 60-250 mm, DA* 300 mm ppkkcao Sold Items 14 11-02-2014 08:42 PM
All times are GMT -7. The time now is 09:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
