07-10-2019, 08:14 PM   #1
Pentax K1 MII microcard problem
When I take the memory card out of my camera and insert it into my computer, it no longer shows any pictures. The second card isn't even recognized as being in the computer. But if I connect the camera to the computer via an USB wire, I can extract photos and they are even recognized by LightRoom.
I had formatted both cards with the camera after the problem initially manifested itself, but they were not recognized by the computer. I tried them in a different computer as a test and had the same results.
Any ideas?
07-10-2019, 08:24 PM   #2
I'd recommend copying over your photos, then formatting the card in the camera or computer to see if that helps.
07-10-2019, 08:46 PM   #3
Not a Number's Avatar
If you format the cards on your computer I recommend that you use SD Formatter which will format the cards to industry specs and not add any OS related files or structures which are often the cause of a camera not recognizing the card.
SD Memory Card Formatter - SD Association
07-10-2019, 08:52 PM   #4
I did format them in the camera after the initial problem hit. But I still couldn't read either in either computer.
---------- Post added 07-10-19 at 08:54 PM ----------
I can't format them in the computer as they don't even register that they exist. However, I hadn't thought about the other stuff a standard PC will "install" so I'll have to see if I can find that formatter.
07-10-2019, 09:04 PM - 1 Like   #5
Likely you have a driver or slot hardware failure on the laptop.
07-10-2019, 09:09 PM   #6
Using the SD Formatter I reformatted one of the cards (the one that the computer registers as existing). I was able to import the two test photos to the computer from the memory card.
The other card still registers with the camera and displays some photos I took, but won't with the computer so I can't format it.
---------- Post added 07-10-19 at 09:14 PM ----------
QuoteOriginally posted by derekkite Quote
Always possible. The slot on the computer was able to read one of the two cards after I formatted it with the SD Formatter (and took a couple of test shots of course). That makes me think the computer is working.
The other card doesn't even register with the computer at all, but it does with the camera. I can review photos there anyway. I deleted two of the six photos that I had on it. Hoping that would somehow magically make it appear, I was disappointed.
07-10-2019, 10:29 PM   #7
If you can, try using a different SD card and see if you have the same problem with the computer reading the card.
07-10-2019, 10:32 PM   #8
Another thing I'll add is that certain built-in card readers may be problematic, either due to bad drivers or the hardware itself. On my 2013 dell, the card reader will occasionally stop working after a card is ejected. It only comes back to life after a reboot, and only if no card is in the slot at that time. So, just something to double-check as well.
07-11-2019, 02:41 AM   #9
Medex's Avatar
I had similar problem with card reader on my old HP laptop. Problem was bad contact between SD slot hardware and the card. I used strip of carton above the SD card (first insert the card, then the strip) and it worked.
07-11-2019, 07:10 AM   #10
You might want to consider replacing the card that the computer won't read. It could be only a matter of time before the camera can't read it either.
Kirk B.
07-11-2019, 07:57 AM   #11
If you connect the camera to the computer with the USB cable does the "bad" card show on the computer? Try using SD Formatter now. Most likely it's a problem with the card but we still can't rule out the slot/reader on the computer. Trying another reader might help narrow down the problem.
Do you have another card reader? If not, how about a Costco or some other place that has DIY photo printing workstations. You can try the card out there.
07-11-2019, 08:17 AM   #12
normhead's Avatar
My computer does this on a regular basis. Sometimes I have to remove the card and reinsert it. Sometimes I have to restart my editing software. Sometimes I have to restart the computer. I've never had file I couldn't in the end load. Sometimes I can copy the files to the computer, and load into my software from the desktop when my software doesn't see it.This happens more with older cards. The original Scandisk I bought with my K-3 will rarely read on the first insert. Newer cards do better. It has to be some malfunction in the way the card makes contact with the computer. But your computer may be different. MIne is 9 years old and if stuff like this wasn't happening I'd be surprised. I think the contacts inside the computer are not as firm as they used to be, 9 years and thousands of inserts later.
07-11-2019, 08:47 AM   #13
Another thing: are you using SD or MicroSD cards? Ricoh advises not to use MicroSD cards. No reason given but probably because the adapters are problematic.
07-11-2019, 08:55 AM   #14
jack002's Avatar
What brand of SD card are you using?
07-11-2019, 05:59 PM   #15
Update. I bought a card reader and was able to read the card on the computer. Just in case, I also bought a SanDisk Extreme Plus SDXC UHS-I Card 128GB. I'll keep it in the camera case for emergencies.
Thanks all for responding!
camera, card, cards, computer, format, k1 mii microcard, memory card, pentax help, pentax k1 mii, photography, photos, read problem, sd, troubleshooting
RAW+, K1 mII, HDR raw files jcdoss Digital Processing, Software, and Printing 6 11-26-2018 01:29 PM
Liliput 5Inch Field Monitor compatibility with Pentax K1 MII Ivetta Pentax Camera and Field Accessories 3 09-08-2018 07:42 PM
K-1 Mii Manual mode has 1/3 of the required information to make an exposure straton Welcomes and Introductions 13 08-28-2018 12:43 AM
For Sale - Sold: Pentax 18-55 MII lens wildlifephotog Sold Items 4 09-17-2009 02:57 PM
Mii, the Wii, and a new lens! Artymous Pentax SLR Lens Discussion 3 12-29-2006 08:27 AM
All times are GMT -7. The time now is 10:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
