07-12-2019, 02:24 AM   #1
In live view mode with a tripod with a series of frames, they are of different sizes
Help! When shooting with a tripod (column) in live view mode on the pentax 645z and a 120mm 1: 4 macro lens with a series of shots, the object turns out to be a dimly sized one!
I shot without live view with a raised mirror. Just in live view mode with a tripod. I have a very massive tripod column, which in theory should exclude any vibration. However, in the end, if I want to shoot several frames with sharpness in different places (to make stacking later), then the objects in the frame are of different sizes (the object does not move and the camera too). Please help with solving this problem!
07-12-2019, 02:32 AM   #2
BigMackCam's Avatar
Welcome to the forums, Yuri
Could you post two or three captured frames to illustrate what you're describing? It would be very helpful for us in getting to the bottom of your problem.
The behaviour you describe sounds to me like "focus breathing", where the angle of view changes with the focus distance. But I confess I'd be surprised if it was noticeable between multiple shots focused at only slightly different distances for the purposes of stacking...
07-12-2019, 02:45 AM   #3
Here is an example of what I'm talking about. Focus on different frames for subsequent stacking. It happens that I take pictures on the 3D table (and do not change the focus point, the object simply rotates around the axis) and stacks with the same problem.
07-12-2019, 02:47 AM   #4
Here are the photos
07-12-2019, 03:43 AM - 1 Like   #5
swanlefitte's Avatar
You need a rail to move the camera back. 1:1 is at the minimum focus distance. Since the lens extends to reach 1:1 as you change focus you are extending your distance and no longer at 1:1.
A work around is to frame at the farthest focus point at 1:1 with what you want in frame. Then as you focus on other parts it gets bigger so you can crop on those frames. Distortion can sometimes be a problem, less if you don't start at 1:1 but maybe 1:1.2
Edit by bigger I meant more stuff in frame. In stack it can resize and that extra can be cropped.
Edit more on focus rail and macro.
www.macrophotobug.com/two-macro-focus-rails-compared/
07-12-2019, 03:57 AM   #6
The stacking software should deal with slight change of subject size/perspective when moving the focus.
07-12-2019, 04:06 AM   #7
Thanks a lot! I'll try to do this
camera, column, frames, mode, object, pentax 645z, pentax fa 120mm, pentax help, photography, rised mirror, series, sizes, stacking, tripod, troubles with 645z, troubleshooting, view, view mode
K50 Exposure is much different from live view to view finder neptune Troubleshooting and Beginner Help 23 02-10-2018 09:07 PM
live view noise and smc dfa 100mm f2.8 macro lens not focusing in live view tommygunn84 Troubleshooting and Beginner Help 7 11-24-2016 08:59 PM
Typical live view humming, when not in live view. lightsource Pentax K-1 & K-1 II 8 05-05-2016 02:20 AM
Do different lenses have different minimum temperatures they can operate at? Sagitta Troubleshooting and Beginner Help 10 05-08-2015 09:09 AM
K5 Live View: Live Exposure Adjustments Visible in "M" Mode? godwinaustin Pentax K-5 & K-5 II 6 08-13-2013 08:11 PM
All times are GMT -7. The time now is 11:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
