07-22-2019, 05:00 PM   #1
K2000 Will Not Turn On
I got a Pentax K2000 today, but it will not turn on.
I cleaned the battery contacts with contact cleaner (they weren't dirty).
Tried new alkaline batteries and fully charged NI-MH batteries, but nothing.
Anyone have any suggestions? Or should I sell it for parts?
07-22-2019, 06:54 PM   #2
ismaelg's Avatar
Hello,
Clean the contacts again but trying to lightly scrape them. Sometimes corrossion is not seen and you need to scrape a little. Also, carefully bend the contacts to ensure more pressure against the batteries.
Hope it works!
Thanks,
07-22-2019, 09:24 PM   #3
paulh's Avatar
Put in a set of new or fully charged batteries and let the camera sit for a day or two and see what happens. Or, try a set of lithium batteries. Good luck.
07-23-2019, 09:12 AM - 1 Like   #4
I have the K2000, wonderful camera, but don't use it anymore. I got a store display model, so when I took home and put in Fresh 'Cheap' Alkaline batteries it didn't start up. So I remember buying Lithium AA batteries and putting it in, it started up. There is a setting in the camera where you can tell what type of battery is being used, change it to Auto and it will start up with cheap batteries too. When the camera became old, even fully charged Eneloops depletes fast.
It was picky on NI-MH batteries too. It only liked Energizer, Rayovac and Eneloop rechargeable NI-MH batteries. Duracell it absolutely hated lol. Panasonic and Sony was ok.
07-23-2019, 09:21 AM   #5
jack002's Avatar
How is the memory card? Is it good? Is it brand name? Have you tried another one?
07-23-2019, 02:34 PM - 1 Like   #6
I tried it with a few different SD cards (Sandisk).
None of the above suggestions have worked, but I haven't tried it with lithium batteries.
I'm going to get some. Will let you know if they work.
Thanks for all the suggestions.
07-23-2019, 04:57 PM   #7
Tried some lithium batteries. No luck.
Going to list it for parts.
07-23-2019, 05:10 PM   #8
QuoteOriginally posted by blumoon722 Quote
Hard luck. Any chance you can return it? Did you buy as-is?
07-25-2019, 12:32 AM   #9
QuoteOriginally posted by paulh Quote
I have found this works if you keep turning the camera on, leaving it on for a few minutes, taking out and re-inserting the batteries, turn on again for a few minutes. Repeat this half a dozen times and then give up. I have tried this on two camera models, K100ds and K-m (2000) and been perhaps lucky as they both started working.
I use lithium batteries, not tried it with re-chargables.
09-14-2019, 01:51 PM   #10
Well....Surprise surprise
I said what the heck and tried the K2000 with the same Energizer Ultimate Lithium batteries I had tried 6 weeks ago.
The camera turned on and I was able to take a few pics which look fine, BUT the screen doesn't work when I try to display the pics or see the menu.
Any suggestions???
batteries, camera, k2000, pentax help, photography, troubleshooting
Not one, not two, not three, not four, but a wedding where half attendees are bob. LeDave Photographic Industry and Professionals 12 05-16-2016 03:40 AM
Nature ...there is a season, turn turn turn... littledrawe Post Your Photos! 4 09-19-2012 11:57 PM
turn left turn right... err no jeffkrol General Talk 33 04-19-2012 09:19 AM
Pentax K2000 LCD screen won't turn on jenniferrrrrrr Visitors' Center 8 12-28-2011 04:01 PM
To turn right or to turn left spura Pentax SLR Lens Discussion 14 04-15-2009 11:29 AM
All times are GMT -7. The time now is 03:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
