Originally posted by Peter61uk Hi all,
Are the “lens pens” any good or should I avoid them
Peter
A mostly unnecessary and complicating way to "clean" a lens, with the possibility of the tip picking up abrasive matter and transferring that to the lens.
Huffing onto a lens and wiping with a microfibre cloth is still the gold standard in simple, uncomplicated cleaning. Occasionally, a single drop of lens cleaner is needed, but nothing else should be applied to any lens (slap on a high quality filter and use that as a 'scratching pad').
A sparkling clean front element, protected by a filter, will rarely need any sort of cleaning. That's the benefit of filters, but don't slap a $5.00 filter on a $5,000 lens — there are entirely good reasons for lenses costing that much, and a cheap filter does them no good at all.
EDIT: I do have a lenspen, bought in 1993, and barely used!
