07-28-2019, 05:17 AM   #16
Sandy Hancock's Avatar
I still don't know what this has to do with skin tones, by the way
07-28-2019, 05:19 AM   #17
GUB
GUB's Avatar
Yep that is red. And beautifully handled.
07-28-2019, 05:35 AM   #18
More red.
And really pushing the red spectrum.
07-28-2019, 07:43 AM   #19
pschlute's Avatar
QuoteOriginally posted by GUB Quote
What is your custom image set to
and what is your white balance set to.
EDIT ps welcome to the forum
And further, what light are you shooting under ?
---------- Post added 07-28-19 at 03:47 PM ----------
Use Adobe RGB as your primary color space. Adobe RGB give some extra headroom for the red tones not to be compressed as much as with sRGB.
This assumes the OP is familiar with colour spaces and converting the image back to sRGB before posting online.
07-28-2019, 12:27 PM   #20
QuoteOriginally posted by MichaelSt Quote
I use a Pentax K3. It seems to have a default preset which over-saturates REDS. This is particularly noticeable with skin tones, which makes every face seem very florid. Of course, I can correct this readily in Photoshop, but I was hoping someone here might guide me into how to reduce red saturation levels in the camera itself. Thank you.
In camera (for JPGs) the options are limited compared to full desktop processing. What you can do is:
  1. Press the info button when selecting a WB method and fine tune it. Red is on the lower right corner, so you can work against red by shifting WB to the top left corner (G7/B7).
  2. Select a custom image option where the hexagonal radar chart shows the green lines for red relatively close to the center (portrait, muted, flat). You do not want a mode that actually pushes the reds.
Read this here: How do you optimize the finishing-touch settings for portraits? / Beautiful Photo-life | RICOH IMAGING It gives pretty extensive suggestions for portrait shooting in JPG.
07-28-2019, 12:55 PM   #21
If you are shooing maximum-quality JPEG images, simply go to the Custom Image menus and switch from the default "Bright" category to the "Natural" category, which is better for skin tones. This provides a different color palette balance along with less contrast. Sharpness is also reduced by one notch, as in the "Bright" category it is increased by one notch by default. Within each category you can also adjust various parameters if you wish to experiment.
adobe, camera, custom image, image, pentax help, photography, red saturation, rgb, srgb, troubleshooting
Nature Red Kite (Milvus Milvus) Over and Over Again ... Ian.morgan Post Your Photos! 8 11-19-2017 04:29 PM
Corel PaintShop Pro X8 over saturation larryinlc Digital Processing, Software, and Printing 4 05-25-2016 08:43 PM
Red saturation K-7 milesy Pentax DSLR Discussion 3 01-17-2012 11:43 AM
red saturation issues.... dcmsox2004 Pentax DSLR Discussion 9 07-02-2009 04:48 PM
How to reduce red channel saturation? jms698 Photographic Technique 8 12-01-2008 09:09 PM
All times are GMT -7. The time now is 05:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
