Originally posted by pschlute Well the Kr is an old model now and 12800 ISO is a hell of a lot better on modern cameras like the KP and K1. Personally I would suggest a camera would be a better upgrade for what you want, but appreciate it is down to cost. f5.6 to f2.8 is two stops so will make a difference if you go down that route (ISO 3200 versus 12800). Also learning some PP skills especially with noise reduction can help too.
Three very different maximum focal lengths there. With your current set-up what FL do you shoot most at ? This has to be one of your main deciding factors.
I am not sure a FF/aps-c comparison is helpful here. The OP has not mentioned FF. Either way his current Kr has less MP than the K1 in crop mode.
Thanks PSchlute. You give another vote for camera improvement over a lens purchase. PP is definitely a time consuming learning curve. But, I am slowly getting there using Affinity. I was able to make some improvements in PP but not to any degree of satisfaction, yet I know there is more I can do there as well. As for FL (focal length? -- I presume) it wanders about as taking pictures during a soccer match (i.e. football over there and most other places) is hard enough, and wandering about gets very tiresome, so I spend most of the time planted and need the reach of a 300 (or more really, but not in my budget) and the closeness of a 50 (or closer sometimes). But, on average, I'm probably around 200.
---------- Post added 08-06-19 at 04:09 PM ----------
Originally posted by BigMackCam I'm another who thinks, in this instance, a K-70 would be a better idea than a faster lens. If you go for a 70-200 f/2.8, you'll lose a fair bit of reach compared to your 55-300 at the long end, which, for sports, could be critical - or, at the very least, frustrating. The K-70's high ISO capability is quite astonishing compared to older bodies like the K-r, plus you get the extra resolution, articulating screen and a bunch of new features (which may or may not be useful to you - but I'd guess at least some of them will be, at some point).
Thanks BigMackCam. The K70 is starting to win by a landslide. I honestly had no idea that the camera improvements were that superior to the point of being able, at least in the comparisons expressed here, overcome the speed for going to f2.8 on the K-r. Wow!!!
---------- Post added 08-06-19 at 04:14 PM ----------
Originally posted by stevebrot Switch to manual exposure (M mode) metering off a gray card or the grass/astro-turf of the field; that should buy a few stops EV.
Whoa Steve! That's like Zen photography for me. BUT, I like it. I have a basic understanding of what you refer to and will now do some homework on it. I'm always up to learning a new skill, even if a K70 resolves my issue. Thanks!
---------- Post added 08-06-19 at 04:16 PM ----------
Oh, also meant to state that I typically shoot in shutter priority mode as that is what is typically recommended for sports photography. Although, I understand real pros often opt for being all M (except focus).
