Good day! I have one question about SR performance on Pentax DSLRs.
Excuse me for my english
I've noticed, that SR sometimes works better at slower shutter speeds, that at faster.
For example, I use Tamron 70-300 at 300 mm on my K20D, K10D, K-5 II. With all cameras I have the same result.
Shots are sharp at 1/125, 1/100 (about 2 stops under 1/EFL). If I set shutter to 1/80, 1/60, 1/40 s shots became blurred. I've decided, that 2-2,3 stops is a technical limit for SR. Not bad.
BUT: I set shutter to 1/30 s, 1/25 s at 300 mm and (suddenly!) shots became sharp! I've done 30 shots and at 1/30 s they were sharper, that at 1/80 s. I mean "not shaked". It isn't occasionally!
I've done 30 shots at 1/50...1/80 s and 30 shots at 1/25...1/30 s. In second series with lower shutter speed shots were sharper!
Why SR works worse at some (not slowest) shutter speeds? Is there some mechanical resonance at 1/50...1/80? Is it possible to repair it programmatically?
Maybe SR works too good at 1/50...1/80 and makes understabilization?
