08-21-2019, 05:29 PM   #1
battery grip AA battery life
Hi I wanted to know if the pentax battery is better/lasts longer than 6 nickle metal hydride batteries. The nmhi batteries weigh alot in the grip and they seem to run out pretty quickly is that normal? I haven't tried the spare pentax battery yet. I was wondering which is better/lasts longer. In the battery grip
thanks,
I've been absent awhile.
08-21-2019, 06:25 PM - 3 Likes   #2
MarkJerling's Avatar
QuoteOriginally posted by enyaw Quote
thanks,
It really depends on the milli amp hour ratings of the batteries and the age and condition of the batteries.
For instance, the Pentax D-LI90 battery is rated at 1860mAh, while Eneloops Pro AA batteries are rated as minimum 1900mAh and up to 2550mAh, but, regular AA batteries may be only 1200mAh.
08-22-2019, 01:01 AM   #3
Hi, the rechargables are rated 2460Mha, fairly new and only used for the battery pack. I'm guessing it's the discharge rate and the fact that they don't charge all the way to 1.5v like a regular AA. Which has a voltage of 1.5-1.57 brand new. Thanks
08-22-2019, 02:29 AM - 3 Likes   #4
Alex645's Avatar
Hi I wanted to know if the pentax battery is better/lasts longer than 6 nickle metal hydride batteries. I was wondering which is better/lasts longer. In the battery grip
On page 284 of the K50 owner's manual their tests indicate that under "normal conditions" at 23 degrees celsius they report:
AA alkaline batteries: 170 shots
D-LI109: 480 shots
AA NiMh (1900 mAh): 580 shots
AA lithium: 1250 shots
And then of course, other factors like flash usage, auto vs. manual focus, video or live view, etc, will reduce those numbers.
This is about what I've found in my own usage of the K50. Nowadays, I rarely shoot more than 480 shots in a days outing, but I always have a freshly charged spare D-Li109 with me. I prefer not to fumble around with six (or 12) AA cells and disposable lithium, although by far the longest lasting, are not cost effective.
Note that the original Pentax D-Li109 was rated at 1200mAh. There are other brands that make a D-Li109 like DSTE that are rated at 2100mAh or Wasabi Power at 2300mAh.
So to answer your question: if your NiMh is rated at 2460mAh, then theoretically they would last longer than even the best D-Li109 like the Wasabi 2300mAh.
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-50.pdf
---------- Post added 08-22-19 at 02:33 AM ----------
Note that NiMh batteries will typically have less voltage than alkaline but higher amperage.
08-23-2019, 12:14 AM   #5
Thanks for the responses. Has anyone done an actual experiment though. I mean between the 2 types of batteries in the grip. Was there a huge difference, if any?
08-23-2019, 03:32 AM - 1 Like   #6
Alex645's Avatar
QuoteOriginally posted by MarkJerling Quote
Ricoh/Pentax has done actual tests or 'experimented' and AA lithium with nearly 10 times the life of AA alkaline is a pretty "huge difference". I doubt anyone other than Ricoh or a battery company has bothered to systematically burn through shutter actuations other than with brand new cells in ideal vs. extreme conditions. But anecdotally the relative life expectancy (actuations per charge) reported in the owner's manual corresponds with reality in my experience.
08-23-2019, 04:33 AM - 2 Likes   #7
Seeker of Knowledge
aslyfox's Avatar
. . . flash usage, auto vs. manual focus, video or live view, . . . .
in my limited experience, battery " life " is very dependent on how you use the camera
in addition to the " factors " listed above, there is another " chimping "
" . . . the habit of checking every photo on the camera display (LCD) immediately after capture . . . "
that takes a toll on battery power, regardless of type of battery
one other factor to consider: how quickly you can shift out a single battery vs. shifting out a number of AA batteries:
I have multiple D 190s, both OEM and third party, and I try to change out the battery kept in the camera body only at home by changing out the battery in the grip in " the field "
08-23-2019, 07:19 PM - 1 Like   #8
aslyfox, aka a sly fox. Jk, all is good I just thought someone did it before. I will do the experiment tomm. And that experiment will require 2 trips no lolz
thanks to all,
I am also a seeker of knowledge
batteries, battery, camera, d-li109, grip, nimh, pentax, pentax battery, pentax help, photography, shots, troubleshooting, voltage, wasabi
Re: K3ii Battery Grip AA Battery Pentax_Scottish_4567 Pentax K-3 7 08-17-2019 11:31 AM
Longest battery life models - Preferably AA battery and waterproof. cadmus Pentax Compact Cameras 8 07-04-2016 08:33 PM
Will the k-3 take the AA battery adapter or do I need to purchase a battery grip Sorver Pentax K-3 8 12-12-2014 01:08 AM
Wanted - Acquired: AA battery tray for Battery Grip BG-4 markf Sold Items 4 07-20-2013 01:47 PM
All times are GMT -7. The time now is 07:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
