Hi Pentaxians , maybe you can help me with this issue. I bought an ESII some days ago in a nice conditon. Everything seemed to be ok with it. The meter pin mooved as it should. But some time after the pin started to go only to 4 when I pressed the shutter, no matter the light conditions. I realized the LR44 batteries were being drainned very fast, in circa 20 minutes. Not all batteries were drainned - and it is the strange thing - but just one of them, as I tested in my multimeter. It went to 0.7v, the other went to 1.35 very fast also. Then I put new batteries and the meter pin reestarted working normally. But after half an hour the new batteries were drained and the pin reestarted to act wrong. I tried everything to prevent it: closed the lenses, let the dial in bulb or manual, but the drainnage occurred again and again.
Certainly the circuit is defective. Is it a common problem? What do you think it could be?
