09-01-2019, 12:57 PM   #1
DNG Files
Just copied DNG files from memory card to computer. Put the memory card back in the camera (K3ii) and it is now saying "No image". However looking at the card again on the computer, the images are there. What Have I done? Tried a different card with images (JPGs) and the camera is still saying "No image". Can anyone help?
09-01-2019, 12:58 PM   #2
Are you sure something is on the other card?
09-01-2019, 01:10 PM   #3
Can you take a new picture on the card and see if THAT shows up?
09-01-2019, 02:08 PM   #4
Please forgive a dumb question - was your camera turned off before you took the card out? You could try removing the battery from the camera, waiting a few minutes, then reinserting it and rechecking for images. Grasping at straws...
09-01-2019, 02:48 PM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by finchamjr Quote
What Have I done?
Did you remember to properly eject/unmount the card(s) from your computer before removing it?
09-01-2019, 03:13 PM - 1 Like   #6
Have you moved the files around on the card? If they're not in the original folder structure (e.g. DCIM/IMGP....) then the camera might not even know where to find them.
09-01-2019, 06:30 PM   #7
ramseybuckeye's Avatar
My question is if have already transferred the pictures to the computer why do you want them on the card? I reformat my cards in camera after each time I load them to the computer, that assures a clean card to write to for each use.
09-01-2019, 07:59 PM - 1 Like   #8
This can be a problem on a Mac, but it should be fixed by reinserting in the computer and ejecting.
Do you have a second card in the camera? If so, the issue might be that when you took the card out, the other card will now be the one you see in the camera when you try to look at photos. If so, you can press the button above the 4-way controller to switch which card's images you are looking at in the camera.
09-01-2019, 09:59 PM   #9
joergens.mi's Avatar
card write proteted?
09-01-2019, 10:09 PM   #10
QuoteOriginally posted by leekil Quote
It can happen on Windows and Linux as well and the fix you suggested often works.
Good suggestion. More than once, I have accidentally toggled the camera into using the other slot when I take a card out to read.
09-02-2019, 05:00 AM   #11
Oldbayrunner's Avatar
Sometimes when you take out card 1 if the camera is started up without it the camera default selects card 2 and will remain on it even when re-inserting card 1 unless card 2 is removed allowing the camera to default back to card 1.. Easy fix, take both cards out of the slot and re-insert card 1 restart the camera, shut it off then re-insert card 2. Now your camera should re-default to reading card 1....
09-02-2019, 05:09 AM   #12
QuoteOriginally posted by selfnoise Quote
Yes, New picture do show up on the card OK.
---------- Post added 09-02-19 at 01:14 PM ----------
QuoteOriginally posted by ramseybuckeye Quote
"My question is if have already transferred the pictures to the computer why do you want them on the card? I reformat my cards in camera after each time I load them to the computer, that assures a clean card to write to for each use."
I do this out of habit. Now you have mentioned it I wonder why! I don't need the files on the card. A habit I will change.
Thank you all for your suggestions/remedies. evwerything seems to be working as it should this morning.
09-02-2019, 01:12 PM   #13
35mmfilmfan's Avatar
What I found once (and only once !) was that, if I did not set write protect BEFORE putting the card into the computer, the computer wrote some data to the card, which confused the camera. Since then, I always set write protect immediately I take the card from the camera. If I forget to remove write protect and re-insert the card in the camera, when I next try to use it, the camera tells me WP is set, no biggie, just do it there and then. And, not intending to resurrect a previous discussion, but I am one of those who uses the card until almost full (maybe 50 exposures left), then use a brand new card, keeping all the old cards, and occasionally (about every six months) doing a backup of all the cards to a separate disc.
09-02-2019, 04:29 PM   #14
I often keep them on the card until I need to free up space on it, just in case there is a failure on the computer side, I will have them temporarily backed up on the card as well.
camera, card, computer, dng, files, habit, images, load, memory, pentax help, photography, picture, pictures, question, reformat, time, troubleshooting
Pentax K3 DNG files woodywesty Digital Processing, Software, and Printing 13 06-22-2018 03:44 PM
DNG Raw Files corrupted by Adobe products JeaPea Digital Processing, Software, and Printing 18 03-05-2018 10:05 PM
Blurry DNG files in Lightroom Lev Troubleshooting and Beginner Help 15 01-22-2018 04:07 PM
Accidentrally deleted DNG files from SD card ... recovered but cannot be opened !? jpzk Troubleshooting and Beginner Help 13 09-15-2017 09:38 AM
DNG in-camera vs DNG from Lightroom? rfortson Digital Processing, Software, and Printing 9 11-02-2008 11:06 PM
All times are GMT -7. The time now is 01:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
