09-03-2019, 10:18 AM   #1
ntrao's Avatar
DA lens aperture setting on other system adapter
Hi Pentaxians,
I want to use my DA15 with Fujifilm camera with help of an adapter. It is always open with minimum F22 stop and there is nothing that I can do to control it. Is there any way, I can keep the DA15 to be open at F8 always when on the adapter? Or are there any special adapter for that purpose? Please help!
---------- Post added 09-03-2019 at 10:58 PM ----------
Google search helped me in finding below adapter, which looks expensive. Does anyone used it?
Vello Pentax K Lens to Fujifilm X-Mount Camera Lens LA-FX-PK-A
09-03-2019, 10:33 AM   #2
Pentax lenses (save for some very recent ones with the KAF4 electromagnetic mount variant) have a mechanical aperture lever; Fujifilm bodies are entirely electronic so they cannot operate the aperture... and DA lenses are by default fully stopped down.
Without an adapter that emulates the aperture lever, you're unfortunately out of luck...
I just checked the adapter; it should work but it seems you'll have a "stepless" aperture, so you'll probably have to put your clinical eye to work
09-03-2019, 11:45 AM   #3
Otis Memorial Pentaxian
QuoteOriginally posted by ntrao Quote
I don't believe any K-to-mirrorless provide f-number aperture ring emulation with DA or D FA series Pentax lenses. That being said, it may be possible to back-calculate an approximation based on metered EV using as Fuji lens and marking with tape or similar on the adapter barrel and ring for the position where the same EV is attained for stop-down metering.
09-03-2019, 12:03 PM   #4
Basically, as long as the adapter has a mechanical aperture ring, it should work. The one you linked looks good.
Of course, you'll be setting the aperture manually, and you won't know the exact value.
09-04-2019, 01:08 AM   #5
Something similar cost ~ US 22 in China.
https://detail.tmall.com/item.htm?spm=a230r.1.14.11.6423157546U0tz&id=522844...27b&abbucket=2
I have one for m43 and it works well
09-16-2019, 09:21 AM   #6
ntrao's Avatar
Thanks everyone for your responses. Last one looks promising. I am thinking about something DIY kind of aperture holder, needs some guts as it may damage the sensor of the camera, if it fails.
adapter, camera, da lens aperture, da15, fujifilm, lens, pentax help, photography, troubleshooting
Simple question on aperture setting on k-30 vs. What lens is capable of Vicioustuna2012 Troubleshooting and Beginner Help 10 11-26-2017 11:25 PM
Aperture control problems with variable aperture lenses (with aperture rings) gtxSeries Troubleshooting and Beginner Help 3 09-13-2017 01:11 PM
DA L 18-55 WR Aperture closes down to minimum regardless of setting bubobubo Troubleshooting and Beginner Help 16 08-13-2016 04:02 PM
Suggestion A "Hater" system, just like the like system Clinton Site Suggestions and Help 42 08-22-2013 06:33 AM
Nikon Q system using 1/2.3" sensor too = Pentax Q system? ogl Pentax News and Rumors 31 07-14-2011 07:47 PM
All times are GMT -7. The time now is 11:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
